Samsung S24E450D 24" 1920x1080 5ms VGA DVI DisplayPort L...
Samsung S24E450D 24" 1920x1080 5ms VGA DVI DisplayPort LED Monitor
£172.51
More than 50 in stock
Delivery:
Standard: 1-3 working days
Key features
  • Built from recycled plastic
  • Less than 0.005 W off-mode power consumption
  • VGA, DVI and DisplayPort connections
  • Diagonal Size: 24in
  • Max Resolution: 1920 x 1080
  • Response Time: 5ms
  • Speakers: None
  • Interfaces: DisplayPort, DVI, VGA (HD-15)
Product codes
The SE450 Series provides an environmentally-friendly, user-friendly and budget-friendly yet high-quality desktop monitor solution for your business. The features of this 24" monitor include a simple and easy-to-use design, fully-adjustable stand, matte bezel with clearly-labeled buttons, versatile connectivity and a low-glare commercial-grade TN panel.
Product Description Samsung S24E450D - SE450 Series - LED monitor - Full HD (1080p) - 24"
Device Type LED-backlit LCD monitor - 24"
Features USB Hub
Panel Type TN
Aspect Ratio 16:9
Native Resolution Full HD (1080p) 1920 x 1080 at 60 Hz
Brightness 250 cd/m²
Contrast Ratio 1000:1
Response Time 5 ms
Colour Support 16.7 million colours
Input Connectors DVI, VGA, DisplayPort
Display Position Adjustments Height, pivot (rotation), swivel, tilt
Colour Black
Dimensions (WxDxH) - with stand 56.54 cm x 22.4 cm x 36.18 cm
Weight 5.87 kg
Environmental Standards ENERGY STAR Qualified
Compliant Standards C-Tick, EN55022, SASO, EN55024, CB, FCC Part 15 B, CCC, IC, PSB, AS/NZS 3548, FCC, UL 60950-1, IEC 60950-1, EN 60950-1, KCC, cULus, KC, KUCAS, SONCAP, GB 9254-2008, KN22, KN24, K60950-1, GB 4943-2011, GB 17625.1-2012
Accessories
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
Samsung S24E450D 24" 1...
£172.51
