The Samsung LED Business Monitor SE650 has been designed to enhance work conditions and efficiency. Featuring Front Tactile Buttons, the SE650 minimizes costly errors found with high usage, which is a common problem with touch type button monitors. Furthermore, with its smarter design, users can still access these buttons when wall mounted, which can be an issue when monitors feature side panel buttons. Adding to the visual experience, the SE650 features a Narrow Matt Bezel. This reduces distraction around display area and delivers an experience that is immersive and engaging.
If you need a work monitor that uses office space efficiently, then Samsung LED Business Monitor SE650 is the perfect choice. From physically moving the monitor with the carrying handle to quickly installing, the SE650 is ready to deliver an efficient and clean work space. The SE650 is also equipped and prepared for you as a VESA Wall mount, providing a multi-screen or wall mounted monitor. Optimizing your office space is now easily achieved with the Samsung LED Business Monitor SE650.
The Samsung LED Business Monitor SE650 has been designed to help boost work efficiency, delivering a tailored experience with its choice of viewer settings. The height-adjustable stand ensures that the screen can always be set at the optimal eye level, which enhances the visual experience while also helping maintain the viewer's body posture. Other features include the tilt and pivot capabilities, which not only increase comfort levels but also introduce ways of working. The SE650 Monitor can rotate 90 degrees, allowing for more appropriate view depending on the work. So, now you can take convenience and efficiency to amazing heights with the Samsung LED Business Monitor SE650.
Product Description | Samsung S24E650BW - SE650 Series - LED monitor - 24" | Device Type | LED-backlit LCD monitor - 24" | Panel Type | Plane to Line Switching (PLS) | Aspect Ratio | 16:10 | Native Resolution | Full HD 1920 x 1200 at 60 Hz | Pixel Pitch | 0.27 mm | Brightness | 250 cd/m² | Contrast Ratio | 1000:1 | Response Time | 4 ms (grey-to-grey) | Colour Support | 16.7 million colours | Input Connectors | DVI, VGA | Display Position Adjustments | Height, pivot (rotation), swivel, tilt | Colour | Black | Dimensions (WxDxH) - with stand | 55.48 cm x 22.4 cm x 38.23 cm | Weight | 5.8 kg | Environmental Standards | ENERGY STAR Qualified | Compliant Standards | C-Tick, SASO, CB, FCC Part 15 B, CCC, PSB, cULus, KC, KUCAS, SONCAP, KCC KN22, KCC KN24 | Manufacturer Warranty | 3-year warranty |
General | |
Display Type | LED-backlit LCD monitor / TFT active matrix |
Diagonal Size | 24" |
Horizontal Viewing Angle | 178 |
Vertical Viewing Angle | 178 |
Backlight Technology | LED backlight |
Features | MagicBright, power off timer, 72% colour gamut, game mode, Mega Dynamic Contrast Ratio, Magic Upscale, Flicker Free technology, Image Size, Eye Saver Mode, Smart Eco Saving |
Colour | Black |
Dimensions (WxDxH) | 55.48 cm x 22.4 cm x 38.23 cm - with stand |
Weight | 5.8 kg |
Connectivity | |
Interfaces | DVI , VGA |
Mechanical | |
Tilt Angle | -3/+20 |
Swivel Angle | 90 |
Rotation Angle | -1/+95 |
Height Adjustment | 130 mm |
Miscellaneous | |
Features | PVC free |
Cables Included | 1 x DVI cable , 1 x VGA cable |
Power | |
Voltage Required | AC 120/230 V |
Power Consumption Operational | 25 Watt |
Power Consumption Stand by | 0.3 Watt |
Software / System Requirements | |
OS Required | Windows 8.1 |
Dimensions & Weight | |
Dimensions & Weight Details | With stand - width: 55.48 cm - depth: 22.4 cm - height: 38.23 cm - weight: 5.8 kg , Without stand - width: 55.48 cm - depth: 5.51 cm - height: 35.94 cm - weight: 4.11 kg |
Environmental Standards | |
ENERGY STAR Certified | Yes |
Manufacturer Warranty | |
Service & Support | Limited warranty - 3 years |
Environmental Parameters | |
Min Operating Temperature | 10 °C |
Max Operating Temperature | 40 °C |
Humidity Range Operating | 10 - 80% (non-condensing) |
