Samsung S24E650PL 23.6" 1920x1080 4ms VGA HDMI DP PLS LE...
Samsung S24E650PL 23.6" 1920x1080 4ms VGA HDMI DP PLS LED Monitor
£160.17
More than 50 in stock
Delivery:
Standard: 1-3 working days
Key features
  • Business tool that produces crystal-clear images
  • Monitor designed to match business needs
  • Maximize workspace with the efficient handle VESA wall mount
  • Conveniently adjust monitor height, tilt, and perspective
  • Save energy and see the results with the energy tree
  • Control power consumption, conserve energy
  • Gentle on the eyes and on the environment
  • Save energy with smart motion technology
  • See your work from the best possible angle
  • Diagonal Size: 23.6in
  • Max Resolution: 1920 x 1080
  • Response Time: 4ms
  • Speakers: Speaker(s)
  • Interfaces: DisplayPort, HDMI, VGA (HD-15)
Product codes
The Samsung LED Business Monitor SE650 has been designed to enhance work conditions and efficiency. Featuring Front Tactile Buttons, the SE650 minimizes costly errors found with high usage, which is a common problem with touch type button monitors. Furthermore, with its smarter design, users can still access these buttons when wall mounted, which can be an issue when monitors feature side panel buttons. Adding to the visual experience, the SE650 features a Narrow Matt Bezel. This reduces distraction around display area and delivers an experience that is immersive and engaging.
If you need a work monitor that uses office space efficiently, then Samsung LED Business Monitor SE650 is the perfect choice. From physically moving the monitor with the carrying handle to quickly installing, the SE650 is ready to deliver an efficient and clean work space. The SE650 is also equipped and prepared for you as a VESA Wall mount, providing a multi-screen or wall mounted monitor. Optimizing your office space is now easily achieved with the Samsung LED Business Monitor SE650.
The Samsung LED Business Monitor SE650 has been designed to help boost work efficiency, delivering a tailored experience with its choice of viewer settings. The height-adjustable stand ensures that the screen can always be set at the optimal eye level, which enhances the visual experience while also helping maintain the viewer's body posture. Other features include the tilt and pivot capabilities, which not only increase comfort levels but also introduce ways of working. The SE650 Monitor can rotate 90 degrees, allowing for more appropriate view depending on the work. So, now you can take convenience and efficiency to amazing heights with the Samsung LED Business Monitor SE650.
Product Description Samsung S24E650PL - SE650 Series - LED monitor - Full HD (1080p) - 23.6"
Device Type LED-backlit LCD monitor - 23.6"
Energy Class Class B
Energy Consumption per Year 36 kWh
Power Consumption (On mode) 25 W
Features USB Hub
Panel Type Plane to Line Switching (PLS)
Aspect Ratio 16:9
Native Resolution Full HD (1080p) 1920 x 1080 at 60 Hz
Pixel Pitch 0.2715 mm
Brightness 250 cd/m²
Contrast Ratio 1000:1
Response Time 4 ms (grey-to-grey)
Colour Support 16.7 million colours
Input Connectors HDMI, VGA, DisplayPort
Display Position Adjustments Height, pivot (rotation), swivel, tilt
Colour Black
Dimensions (WxDxH) - with stand 55.46 cm x 22.4 cm x 35.73 cm
Weight 5.63 kg
Compliant Standards C-Tick, EN55022, SASO, EN55024, CISPR 22, CB, FCC Part 15 B, CCC, IC, PSB, AS/NZS 3548, FCC, UL 60950-1, IEC 60950-1, EN 60950-1, KCC, cULus, KC, KUCAS, SONCAP, GB 9254-2008, KN22, KN24, K60950-1, GB 4943-2011, GB 17625.1-2012
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
Samsung S24E650PL 23.6...
£160.17
