Samsung S24E650XW 24" 1920x1080 4ms VGA DVI DP USB PLS L...
Samsung S24E650XW 24" 1920x1080 4ms VGA DVI DP USB PLS LED Monitor
£221.88
Delivery:
Key features
  • Business tool that produces crystal-clear images
  • Monitor designed to match business needs
  • Maximize workspace with the efficient handle VESA wall mount
  • Conveniently adjust monitor height, tilt, and perspective
  • Save energy and see the results with the energy tree
  • Control power consumption, conserve energy
  • Gentle on the eyes and on the environment
  • Save energy with smart motion technology
  • See your work from the best possible angle
  • Diagonal Size: 24in
  • Max Resolution: 1920 x 1200
  • Response Time: 4ms
  • Speakers: Speaker(s)
  • Interfaces: DisplayPort, DVI, VGA (HD-15)
Product codes
Samsung's SE650 eco-friendly LCD monitor delivers an unmatched user experience, while maximizing energy savings and sustainable design for reduced environmental impact. Using the monitor's Eco-power off mode the SE650 offers 0.00 W power consumption when in off mode. This is significantly lower than the 0.3 W to 0.5 W experienced with the average monitor, leading to significant savings in energy, resource and cost over time. Along with superior power consumption, the monitor is designed with a recycled plastic and PVC-free body. The recycled plastic and PVC-free body offer health and environmental benefits throughout the monitor's lifecycle, beginning with production, where it reduces the emission of harmful pollutants. During use, the monitor keeps PVC-related toxins out of the user's home, school and office. Finally, when correctly disposed, the monitor prevents PVC from leaking into soil, crops and water supplies.
Product Description Samsung S24E650XW - SE650 Series - LED monitor - 24"
Device Type LED-backlit LCD monitor - 24"
Features USB Hub
Panel Type Plane to Line Switching (PLS)
Aspect Ratio 16:10
Native Resolution 1920 x 1200 at 60 Hz
Pixel Pitch 0.27 mm
Brightness 250 cd/m²
Contrast Ratio 1000:1
Response Time 4 ms (grey-to-grey)
Colour Support 16.7 million colours
Input Connectors DVI, VGA, DisplayPort
Display Position Adjustments Height, pivot (rotation), swivel, tilt
Colour Black
Dimensions (WxDxH) - with stand 55.48 cm x 22.4 cm x 38.73 cm
Weight 5.8 kg
Environmental Standards ENERGY STAR Qualified
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
Samsung S24E650XW 24"...
£221.88
