Samsung S24F350H 23.5" 1920x1080 4ms VGA HDMI PLS LED Mo...
Samsung S24F350H 23.5" 1920x1080 4ms VGA HDMI PLS LED Monitor
£112.93
Select:
More than 50 in stock
Delivery:
Standard: 3-5 working days
  • Diagonal Size: 24in
  • Max Resolution: 1920 x 1080
  • Response Time: 4ms
  • Speakers: None
  • Interfaces: HDMI, VGA (HD-15)
Product codes
Bundle deals (3)
SAMSUNG GALAXY BUDS+
= £241.93
Save £10.00
SAMSUNG GALAXY BUDS - BLACK
= £226.93
Save £5.00
ANTIBACTERIAL WIPES
ANTIBACTERIAL WIPES
= £116.42
Save £1.50
Samsung SF350 Series S24F350FHU LED monitor 24" 1920 x 1080 Full HD (1080p).Plane to Line Switching with 250 cd/m², 1000:1, 4 ms . Interfaces are HDMI and VGA in shiny black
Product Description Samsung S24F350FHU - SF350 Series - LED monitor - Full HD (1080p) - 24"
Device Type LED-backlit LCD monitor - 24"
Energy Class Class A
Energy Consumption per Year 29 kWh
Power Consumption (On mode) 20 W
Adaptive-Sync Technology AMD FreeSync
Panel Type Plane to Line Switching (PLS)
Aspect Ratio 16:9
Native Resolution Full HD (1080p) 1920 x 1080 at 60 Hz
Brightness 250 cd/m²
Contrast Ratio 1000:1
Response Time 4 ms (grey-to-grey)
Colour Support 16.7 million colours
Input Connectors HDMI, VGA
Display Position Adjustments Tilt
Colour Shiny black
Dimensions (WxDxH) - with stand 57.44 cm x 20.65 cm x 41.8 cm
Weight 3.3 kg
Buy used stock
What is used stock?
Item condition
Accessories
Packaging
Functional
Software
Manuals
product
Customer return - item has been repaired under warranty by the manufacturer
Ref: D7D0 043053
£84.97
product
Ref: D7D0 043053
Accessories
Packaging
Functional
Software
Manuals
£84.97
What does this mean?
  • This part of the stock item is present and in good condition
  • This part of the stock item is not present or functional
  • This part of the stock item is damaged in some way. This damage may not render this part of the stock unusable.
  • This part of the stock item is not applicable e.g. it might not include accessories or software as standard
  • This item has not been tested.
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
Samsung S24F350H 23.5"...
£112.93
