Samsung S24H650GDU 24" 1920x1200 4ms VGA HDMI DP PLS LED...
Samsung S24H650GDU 24" 1920x1200 4ms VGA HDMI DP PLS LED Monitor
£205.32
Select:
Hurry, only 2 left in stock!
Delivery:
Standard: 1-3 working days
Key features
  • Consistent colors at any viewing angle
  • Long-lasting eye comfort
  • Built to fit your business space
  • Smart cost saver
  • Multiple-connectivity
  • Diagonal Size: 24in
  • Max Resolution: 1920 x 1200
  • Response Time: 4ms
  • Speakers: None
  • Interfaces: DisplayPort, HDMI, VGA (HD-15)
Product codes
The SH650 Series is a just-right fit for any professional work environment, with its high-end PLS panel whereon texts are thoroughly vivid and images crystal clear, without color shift, from whichever angle they are looked at.
The Eye Saver Mode reduces blue light emissions, which are known to cause damage to the retina and in turn helps you minimize eye strain when working long hours, thus keeping your productivity afloat. Further, the Flicker Free technology offers you a comfortable viewing experience.
The SH650 Series monitor swivels, tilts, pivots and is height-adjustable, ready to meet the needs of any usage scenario. VESA-supported, it can be installed on a wall or separate arms with ease. Its sleek yet sturdy build, coupled with clean back design, blends in perfectly with any office or personal space.
The SH650 Series comes with power-saving modes including SMART Eco Saving which automatically adjusts the brightness of the display based on the colors displayed, and the zero-watt consumption function that brings down power consumption to practically nil when the screen is turned off.
The SH650 provides multi-connectivity with D-sub, DP, HDMI and USB ports on the back of the monitor, prepared to be connected with whatever devices your team or your client chooses to connect for better business outcomes.
Product Description Samsung S24H650GDU - SH65 Series - LED monitor - Full HD (1080p) - 24"
Device Type LED-backlit LCD monitor - 24"
Energy Class Class A
Energy Consumption per Year 34 kWh
Power Consumption (On mode) 23 W
Features USB Hub
Panel Type Plane to Line Switching (PLS)
Aspect Ratio 16:10
Native Resolution Full HD (1080p) 1920 x 1200 at 60 Hz
Brightness 250 cd/m²
Contrast Ratio 1000:1
Response Time 4 ms (grey-to-grey)
Colour Support 16.7 million colours
Input Connectors HDMI, VGA, DisplayPort
Display Position Adjustments Height, pivot (rotation), swivel, tilt
Colour Black
Dimensions (WxDxH) - with stand 55.86 cm x 23.6 cm x 54.58 cm
Weight 6.7 kg
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
Samsung S24H650GDU 24"...
£205.32
