Samsung S24H850 24" 2560x1440 5ms HDMI DP LED Monitor
£208.59
Select:
More than 50 in stock
Delivery:
Standard: 1-3 working days
Key features
  • Consistent colors at any viewing angle
  • Extend and duplicate with daisy chain
  • Eye Saver mode
  • Increase your ergonomic efficiency
  • Diagonal Size: 24in
  • Max Resolution: 2560 x 1440
  • Response Time: 5ms
  • Speakers: None
  • Interfaces: DisplayPort, HDMI
Product codes
Bundle deals (3)
SAMSUNG GALAXY BUDS+
= £337.59
Save £10.00
SAMSUNG GALAXY BUDS - BLACK
= £322.59
Save £5.00
ANTIBACTERIAL WIPES
ANTIBACTERIAL WIPES
= £212.08
Save £1.50
The SH85 is a just-right fit for any professional work environment. Its high-end PLS display, borderless on three sides, has a high pixel density, where texts are thoroughly vivid and images crystal clear without color shift, from whichever angle they are looked at. The SH85's daisy chain function allows extension and replication in multi-monitor settings with just a single DP cable connection. You can display its onscreen content on a second monitor at the same resolution. Communications in conference settings become a whole lot easier with the SH85.
Eye Saver mode reduces blue light emissions, which are known to cause damage to the retina, and in turn helps you minimize eye strain when working long hours, thus keeping your productivity afloat. Further, Flicker Free technology offers you a comfortable viewing experience. It swivels, tilts, pivots, and is height-adjustable, ready to meet the needs of any usage scenario. VESA-supported, it can be installed on a wall or separate arms with ease. Its sleek yet sturdy build, coupled with clean back design, blends in perfectly with any office or personal space.
Product Description Samsung S24H850QFU - SH850 Series - LED monitor - 24"
Device Type LED-backlit LCD monitor - 24"
Energy Class Class C
Energy Consumption per Year 55 kWh
Power Consumption (On mode) 38 W
Adaptive-Sync Technology AMD FreeSync
Features USB Hub
Panel Type Plane to Line Switching (PLS)
Aspect Ratio 16:9
Native Resolution 2560 x 1440 at 60 Hz
Brightness 300 cd/m²
Contrast Ratio 1000:1
Response Time 5 ms (grey-to-grey)
Colour Support 16.7 million colours
Input Connectors HDMI, DisplayPort
Display Position Adjustments Height, pivot (rotation), swivel, tilt
Colour Black
Dimensions (WxDxH) - with stand 54.04 cm x 23.6 cm x 52.31 cm
Weight 6.4 kg
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
Samsung S24H850 24" 25...
£208.59
