Samsung S24R650FDU 24" 1920x1080 5ms HDMI DP LED Monitor
£213.99
12 In Stock
Delivery:
Standard: 1-3 working days
  • Diagonal Size: 24in
  • Max Resolution: 1920 x 1080
  • Response Time: 5ms
  • Speakers: None
  • Interfaces: VGA (HD-15), HDMI, DisplayPort
Product codes
Focus on a full screen
A minimal bezel brings maximum concentration. The virtually borderless screen shows you the full picture and looks almost gapless when used in a dual-monitor setup. See more at once with no distractions in your way, and get through larger sections of your to-do list during screen time.
True colour preservation
Perfect colour down to the last detail. The IPS panel preserves vividness and clarity across every inch of the screen. Work comfortably on the productivity-boosting wide display. From 178¢ª all around, tones and shades look accurate and without colour washing.
Ready to connect
More ports and peripherals for multiple possibilities. Connect to virtually any device with the triple HDMI, DP and DVI interface. Built-in speakers bring on-demand listening. There's no need to dedicate precious desk space to another pair or disrupt your workflow to plug in headphones.
Product Description Samsung S24R650FDU - SR65 Series - LED monitor - Full HD (1080p) - 24"
Device Type LED-backlit LCD monitor - 24"
Energy Class Class E
Energy Consumption per Year 26 kWh
Power Consumption (On mode) 18 W
Adaptive-Sync Technology AMD FreeSync
Features USB Hub
Panel Type IPS
Aspect Ratio 16:9
Native Resolution Full HD (1080p) 1920 x 1080 at 75 Hz
Brightness 250 cd/m²
Contrast Ratio 1000:1
Response Time 5 ms (grey-to-grey)
Colour Support 16.7 million colours
Colour Gamut 72% (NTSC 1976)
Input Connectors HDMI, VGA, DisplayPort
Display Position Adjustments Height, pivot (rotation), swivel, tilt
Voltage AC 120/230 V
Colour Dark grey/blue
Dimensions (WxDxH) - with stand 53.94 cm x 20.05 cm x 47.38 cm
Weight 5.1 kg
Environmental Standards TCO Certified Displays 8, ENERGY STAR Qualified
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
£213.99
