Samsung S27A800NMU 27" 3840x2160 5ms HDMI DP LED Monitor
£364.57
More than 50 in stock
Delivery:
Standard: 1-3 working days
  • Diagonal Size: 27in
  • Max Resolution: 3840 x 2160
  • Response Time: 5ms
  • Speakers: None
  • Interfaces: DisplayPort, HDMI
Product codes
See greatness from any angle
IPS panel Optimised for professional work environments, Samsung high-resolution monitors feature an IPS panel delivering crystal clear colour quality and a wide viewing angle of 178°. Every user can expect a great viewing experience from any angle in vivid and vibrant colour without washing or fade.
Enjoy a billion colours with incredible depth
1 billion colours with HDR 10 Enjoy any content in stunning colour accuracy and detail. With a wide range of colours, near limitless hues and HDR10, which makes dark colours darker and the brightest colours even brighter, every piece of content becomes a joy to look at and can be experienced exactly as the creator intended.
Relieve your eyes from strain
TUV certified Intelligent Eye Care Keep your eyes fresh and strain-free. For those late-night projects, brightness and color temperature adjust automatical for optimisation in any environment. TUV-certified for intelligent eye care, Samsung protects eyes against excessive blue light with eye saver mode and flicлук free feature.
Maximise comfort, minimise distractions
Position your monitor for optimal comfort. Borderless design, VESA mount compatibility and a variety of tilt, swivel and pivot control points allow you to mount your monitor in any environment. In addition, a slim metal stand and narrow depth take up less desk space for a clean, seamless work setup.
Create a sustainable future
Transform your eco-friendly, FSC-certified packaging into practical tools or choose to recycle for enhanced sustainabilty. Globally certified for energy efficiency, Samsung monitor features eco saving plus mode that preserves up to 10% more energy, while maintaining bright and vivd picture quality.
Plug and see
Auto Source Switch No more switching around. With Automatic Source Switch Plus, your monitor detects newly connected devices as soon they're plugged in and displays the correct signal. No more searching for the right input on the menu.
Product Description Samsung S27A800NMU - S80A Series - LED monitor - 4K - 27" - HDR
Device Type LED-backlit LCD monitor - 27"
Energy Class Class G
Power Consumption (On mode) 28 W
Features USB 3.0 hub
Panel Type IPS
Aspect Ratio 16:9
Native Resolution 4K 3840 x 2160 at 60 Hz
Brightness 300 cd/m²
Contrast Ratio 1000:1
HDR Capable HDR10
Response Time 5 ms
Colour Support 1.07 billion colours
Input Connectors HDMI, DisplayPort
Display Position Adjustments Height, pivot (rotation), swivel, tilt
Voltage AC 120/230 V
Colour Black
Dimensions (WxDxH) - with stand 61.55 cm x 19.64 cm x 55.19 cm
Weight 6.4 kg
Environmental Standards TCO Certified Displays 8, ENERGY STAR Qualified
Compliant Standards TUV
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
£364.57
