The SH65 series is a just-right fit for any professional work environment, with its advanced PLS panel where texts are thoroughly vivid and images crystal clear, without color shift, from whichever angle they are looked at.
Samsung SH65 Series S27H650FDU - LED monitor - Full HD (1080p) - 27"
LED-backlit LCD monitor - 27"
Energy Class
Class A
Energy Consumption per Year
37 kWh
Power Consumption (On mode)
25 W
USB Hub
Panel Type
Plane to Line Switching (PLS)
Aspect Ratio
16:9
Native Resolution
Brightness
250 cd/m²
Contrast Ratio
1000:1
Response Time
5 ms (grey-to-grey)
Colour Support
16.7 million colours
Input Connectors
HDMI, VGA, DisplayPort
Display Position Adjustments
62.98 cm x 23.6 cm x 54.96 cm
6.9 kg
Display Type
Energy Class
Class A
37 kWh
25 W
Diagonal Size
27"
Built-in Devices
USB Hub
Panel Type
Aspect Ratio
16:9
Native Resolution
Brightness
250 cd/m²
Contrast Ratio
1000:1
Colour Support
Response Time
5 ms (grey-to-grey)
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Backlight Technology
LED backlight
MagicBright, game mode, Mega Dynamic Contrast Ratio, Magic Upscale, Image Size, Smart Eco Saving, Off Timer Plus
62.98 cm x 23.6 cm x 54.96 cm - with stand
6.9 kg
HDMI , VGA , DisplayPort , USB
Mechanical
Tilt Angle
-5/+24
Swivel Angle
90
Rotation Angle
-2/+92
Height Adjustment
135 mm
Flat Panel Mount Interface
100 x 100 mm
1 x HDMI cable
AC 120/230 V
25 Watt
Power Consumption Stand by
0.3 Watt
Power Consumption (Off Mode)
0.005 Watt
Dimensions & Weight Details
With stand - width: 62.98 cm - depth: 23.6 cm - height: 54.96 cm - weight: 6.9 kg , Without stand - width: 62.98 cm - depth: 7.68 cm - height: 37.1 cm - weight: 4.7 kg
10 °C
10 - 80% (non-condensing)
Customer reviews
