The SH85 is a just-right fit for any professional work environment. Its high-end PLS display, borderless on three sides, has a high pixel density, where texts are thoroughly vivid and images crystal clear without color shift, from whichever angle they are looked at. The SH85's daisy chain function allows extension and replication in multi-monitor settings with just a single DP cable connection. You can display its onscreen content on a second monitor at the same resolution. Communications in conference settings become a whole lot easier with the SH85.
Eye Saver mode reduces blue light emissions, which are known to cause damage to the retina, and in turn helps you minimize eye strain when working long hours, thus keeping your productivity afloat. Further, Flicker Free technology offers you a comfortable viewing experience. It swivels, tilts, pivots, and is height-adjustable, ready to meet the needs of any usage scenario. VESA-supported, it can be installed on a wall or separate arms with ease. Its sleek yet sturdy build, coupled with clean back design, blends in perfectly with any office or personal space.
Product Description | Samsung S27H850QFU - SH850 Series - LED monitor - 27" | Device Type | LED-backlit LCD monitor - 27" | Energy Class | Class B | Energy Consumption per Year | 58 kWh | Power Consumption (On mode) | 40 W | Adaptive-Sync Technology | AMD FreeSync | Features | USB Hub | Panel Type | Plane to Line Switching (PLS) | Aspect Ratio | 16:9 | Native Resolution | 2560 x 1440 at 60 Hz | Brightness | 350 cd/m² | Contrast Ratio | 1000:1 | Response Time | 4 ms (grey-to-grey) | Colour Support | 1.07 billion colours | Input Connectors | HDMI, DisplayPort | Display Position Adjustments | Height, pivot (rotation), swivel, tilt | Colour | Black | Dimensions (WxDxH) - with stand | 61.19 cm x 23.6 cm x 54.37 cm | Weight | 8 kg |
General | |
Display Type | LED-backlit LCD monitor / TFT active matrix |
Diagonal Size | 27" |
Viewable Size | 26.9" |
Built-in Devices | USB Hub |
Horizontal Viewing Angle | 178 |
Vertical Viewing Angle | 178 |
Backlight Technology | LED backlight |
Features | Picture in picture, MagicBright, picture by picture, game mode, Mega Dynamic Contrast Ratio, Magic Upscale, Flicker Free technology, daisy chain compatible, Eye Saver Mode, Smart Eco Saving |
Colour | Black |
Dimensions (WxDxH) | 61.19 cm x 23.6 cm x 54.37 cm - with stand |
Weight | 8 kg |
Connectivity | |
Interfaces | HDMI , DisplayPort , Headphones , USB |
Mechanical | |
Tilt Angle | -5/+24 |
Swivel Angle | 90 |
Rotation Angle | 94 |
Height Adjustment | 135 mm |
VESA Mounting Interface | 100 x 100 mm |
Miscellaneous | |
Cables Included | 1 x HDMI cable |
Power | |
Voltage Required | AC 120/230 V |
Power Consumption Operational | 40 Watt |
Power Consumption Stand by | 0.5 Watt |
Power Consumption (Off Mode) | 0.3 Watt |
Dimensions & Weight | |
Dimensions & Weight Details | With stand - width: 61.19 cm - depth: 23.6 cm - height: 54.37 cm - weight: 8 kg , Without stand - width: 61.19 cm - depth: 7.72 cm - height: 36.61 cm - weight: 5.8 kg |
Environmental Parameters | |
Min Operating Temperature | 10 °C |
Max Operating Temperature | 40 °C |
