Samsung S27R750Q 27" 4K UHD Space Monitor
£349.05
Delivery:
Standard: 1-3 working days
Key features
  • Space-saving design
  • Concealed cables
  • Stylish design
  • Height-adjustable arm stand
  • Adjustable eye level
  • Diagonal Size: 27in
  • Max Resolution: 2560 x 1440
  • Response Time: 4ms
  • Speakers: None
  • Interfaces: HDMI, Mini DisplayPort
Product codes
The Samsung SR75 Series is designed to let you reclaim your work space. Occupying a minimum of desk space and leaving work areas clear when not in use, the Samsung monitor is the ideal solution wherever space is at a premium.
Product Description Samsung S27R750Q - SR75 Series - LED monitor - 27"
Device Type LED-backlit LCD monitor - 27"
Energy Class Class C
Energy Consumption per Year 70 kWh
Power Consumption (On mode) 48 W
Panel Type VA
Aspect Ratio 16:9
Native Resolution WQHD 2560 x 1440 at 144 Hz
Brightness 250 cd/m²
Contrast Ratio 3000:1
Response Time 4 ms (grey-to-grey)
Colour Support 1 billion colours
Input Connectors HDMI, Mini DisplayPort
Display Position Adjustments Height, tilt
Colour Black
Dimensions (WxDxH) - with stand 61.48 cm x 11.55 cm x 73.03 cm
Weight 5.8 kg
Buy used stock
What is used stock?
Item condition
Accessories
Packaging
Functional
Software
Manuals
product
Customer return - item has been opened but is in excellent condition
Ref: F5JN 042115
£311.00
product
Ref: F5JN 042115
Accessories
Packaging
Functional
Software
Manuals
£311.00
What does this mean?
  • This part of the stock item is present and in good condition
  • This part of the stock item is not present or functional
  • This part of the stock item is damaged in some way. This damage may not render this part of the stock unusable.
  • This part of the stock item is not applicable e.g. it might not include accessories or software as standard
  • This item has not been tested.
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
Samsung S27R750Q 27" 4...
£349.05
