Quad HD LED display
See more detail with the Samsung LS32A600NWUXXU Quad HD 32" LED Monitor. Its QHD display with HDR10 gives you rich contrast and vibrant colours, so everything on screen looks crisp and clear.
AMD FreeSync
Immerse yourself in your movies and games with AMD FreeSync. It matches the monitor refresh rate with your graphics card, so you get smooth, lag-free images.You can also tilt, swivel and pivot the screen, so it's easy to find the perfect viewing angle.
Intelligent Eye Care
Stay comfortable while you work – the monitor's Eye-Saver mode protects your eyes during long sessions at the computer. It also uses flicker-free technology, so you can work or relax without any distracting screen flicker.
Product Description | Samsung S32A600NWU - S60A Series - LED monitor - QHD - 32" - HDR | Device Type | LED-backlit LCD monitor - 32" | Energy Class | Class F | Power Consumption (On mode) | 32 W | Adaptive-Sync Technology | AMD FreeSync | Features | USB 3.0 hub | Panel Type | VA | Aspect Ratio | 16:9 | Native Resolution | QHD 2560 x 1440 at 75 Hz | Brightness | 300 cd/m² | Contrast Ratio | 3000:1 | HDR Capable | HDR10 | Response Time | 5 ms | Colour Support | 1.07 billion colours | Input Connectors | HDMI, DisplayPort | Display Position Adjustments | Height, pivot (rotation), swivel, tilt | Voltage | AC 120/230 V | Colour | Black | Dimensions (WxDxH) - with stand | 71.62 cm x 21.14 cm x 58.05 cm | Weight | 6.9 kg |
General | |
Display Type | LED-backlit LCD monitor / TFT active matrix |
Energy Class (HDR) | Class G |
Diagonal Size | 32" |
Built-in Devices | USB 3.0 hub |
Panel Type | VA |
HDR Format | HDR10 |
Horizontal Viewing Angle | 178 |
Vertical Viewing Angle | 178 |
Backlight Technology | LED backlight |
Features | Picture by picture, game mode, Eco Light Sensor, Flicker Free technology, Image Size, Eco Saving Plus, Eye Saver Mode, Off Timer Plus, Picture-in-Picture, Adaptive Picture, Auto Source Switch |
Colour | Black |
Dimensions (WxDxH) | 71.62 cm x 21.14 cm x 58.05 cm - with stand |
Weight | 6.9 kg |
Connectivity | |
Interfaces | DisplayPort 1.2 , Headphones , HDMI , 3 x USB 3.0 , USB 2.0 |
Mechanical | |
Tilt Angle | -2/+25 |
Swivel Angle | 60 |
Rotation Angle | -2/+92 |
Height Adjustment | 120 mm |
VESA Mounting Interface | 100 x 100 mm |
Miscellaneous | |
Features | Security lock slot (cable lock sold separately) |
Cables Included | 1 x HDMI cable , 1 x SuperSpeed USB cable |
Security Slot Type | Kensington security slot |
Power | |
Input Voltage | AC 120/230 V |
Power Consumption SDR (On mode) | 32 kWh/1000h |
Power Consumption HDR (On mode) | 50 kWh/1000h |
Power Consumption (Typical) | 32 Watt |
Power Consumption Stand by | 0.5 Watt |
Power Consumption (Off Mode) | 0.3 Watt |
Dimensions & Weight | |
Dimensions & Weight Details | With stand - width: 71.62 cm - depth: 21.14 cm - height: 58.05 cm - weight: 6.9 kg , Without stand - width: 71.62 cm - depth: 4.13 cm - height: 42.47 cm - weight: 4.8 kg |
Dimensions & Weight (Shipping) | |
Shipping Width | 80 cm |
Shipping Depth | 17.1 cm |
Shipping Height | 51.1 cm |
Shipping Weight | 9 kg |
Environmental Parameters | |
Min Operating Temperature | 10 °C |
Max Operating Temperature | 40 °C |
Humidity Range Operating | 10 - 80% (non-condensing) |
To help you find items available at this time, we’re only showing items we have in stock to avoid backorders. Pop your email address below and we’ll let you know when this item is back in stock:
