Samsung S32A600UUU 32" 2560x1440 5ms HDMI DP USB-C LED M...
Samsung S32A600UUU 32" 2560x1440 5ms HDMI DP USB-C LED Monitor
£391.40
29 in stock
Delivery:
Standard: 1-3 working days
  • Diagonal Size: 32in
  • Max Resolution: 2560 x 1440
  • Response Time: 5ms
  • Speakers: None
  • Interfaces: HDMI, DisplayPort, USB-C
Product codes
Quad HD LED display
See more detail with the Samsung LS32A600UUUXXU Quad HD 32" LED Monitor. Its Quad HD display with HDR10 gives you rich contrast and vibrant colours, so everything on screen looks crisp and clear.
AMD FreeSync
Immerse yourself in your movies and games with AMD FreeSync. It matches the monitor refresh rate with your graphics card, so you get smooth, lag-free images. And with the wide viewing angles you can see everything clearly, even from the side or above.
Intelligent Eye Care
Stay comfortable while you work – the monitor's Eye-Saver mode protects your eyes during long sessions at the computer. It also uses flicker-free technology, so you can work or relax without any distracting screen flicker.
Product Description Samsung S32A600UUU - LED monitor - QHD - 32" - HDR
Device Type LED-backlit LCD monitor - 32"
Energy Class Class G
Energy Consumption per Year 51 kWh
Power Consumption (On mode) 37 W
Features USB 3.0/USB-C hub, Ethernet network adapter
Panel Type VA
Aspect Ratio 16:9
Native Resolution QHD 2560 x 1440 at 75 Hz
Brightness 300 cd/m²
Contrast Ratio 3000:1
HDR Capable HDR10
Response Time 5 ms
Colour Support 1.07 billion colours
Input Connectors HDMI, DisplayPort, USB-C
Display Position Adjustments Height, pivot (rotation), swivel, tilt
Voltage AC 120/230 V
Colour Black
Dimensions (WxDxH) - with stand 71.62 cm x 21.14 cm x 58.05 cm
Weight 7.2 kg
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
£391.40
