The SD850 has 2560 x 1440 wide quad high-definition (WQHD) resolution, twice that of Full HD, with a 178° viewing angle. The monitor can display over one billion colors, incorporating 100 per cent of the sRGB color space. Its approximate 3.7 million pixels offer deep and rich image detail for a more realistic picture. Aimed at content creaters, programmers and those in financial services, the monitor can not only display picture-in-picture in 720p, but also picture-by-picture to display images from two separate sources, such as a laptop and a desktop PC.
The SD850 has an eco light sensor that adapts the brightness of the monitor dynamically according to available light to save power. The monitor also has an Energy Star rating of 6.0 to ensure efficiency. The materials that make up the SD850 have also been TCO Certified.
Product Description | Samsung S32D850T - SD850 Series - LED monitor - 32" | Device Type | LED-backlit LCD monitor - 32" | Energy Class | Class B | Energy Consumption per Year | 82 kWh | Power Consumption (On mode) | 56 W | Features | USB 3.0 hub | Panel Type | MVA | Aspect Ratio | 16:9 | Native Resolution | 2560 x 1440 | Pixel Pitch | 0.27675 mm | Brightness | 300 cd/m² | Contrast Ratio | 3000:1 | Response Time | 5 ms (grey-to-grey) | Colour Support | 1 billion colours | Input Connectors | HDMI, DVI, DisplayPort | Display Position Adjustments | Height, pivot (rotation), swivel, tilt | Colour | Titanium silver, matte black | Dimensions (WxDxH) - with stand | 74.13 cm x 28 cm x 50 cm | Weight | 12.2 kg | Compliant Standards | UL, TUV, VCCI, C-Tick, EN55022, EN55024, CB, CCC, PSB, AS/NZS 3548, KCC, FCC Part 15 B Class A, KC, GB 9254-2008, GB 17625.1-2003 EMC, KN22, KN24 | Manufacturer Warranty | 3-year warranty |
General | |
Display Type | LED-backlit LCD monitor / TFT active matrix |
Diagonal Size | 32" |
Built-in Devices | USB 3.0 hub |
Panel Type | MVA |
Horizontal Viewing Angle | 178 |
Vertical Viewing Angle | 178 |
Backlight Technology | LED backlight |
Features | Picture in picture, power off timer, MagicBright 3, game mode, Mega Dynamic Contrast Ratio, Eco Light Sensor, Eco Saving, Magic Upscale, auto-rotation, Mercury free, Image Size |
Dimensions (WxDxH) | 74.13 cm x 28 cm x 50 cm - with stand |
Weight | 12.2 kg |
Connectivity | |
Interfaces | DVI , DisplayPort , HDMI , Audio line-in , Headphones , USB 3.0 upstream , 4 x USB 3.0 downstream |
Mechanical | |
Tilt Angle | -5/+20 |
Swivel Angle | 60 |
Height Adjustment | 130 mm |
VESA Mounting Interface | 100 x 100 mm, 200 x 200 mm |
Miscellaneous | |
Cables Included | 1 x HDMI cable , 1 x DVI cable , 1 x USB cable , 1 x DisplayPort cable , 1 x Mini DisplayPort-DisplayPort adapter |
Power | |
Power Supply | Internal |
Voltage Required | AC 120/230 V (50/60 Hz) |
Power Consumption Operational | 46 Watt |
Power Consumption Stand by | 0.45 Watt |
Dimensions & Weight | |
Dimensions & Weight Details | With stand - width: 74.13 cm - depth: 28 cm - height: 50 cm - weight: 12.2 kg , Without stand - width: 74.13 cm - depth: 6.85 cm - height: 44.1 cm - weight: 9.4 kg |
Manufacturer Warranty | |
Service & Support | Limited warranty - 3 years |
Environmental Parameters | |
Min Operating Temperature | 10 °C |
Max Operating Temperature | 40 °C |
Humidity Range Operating | 10 - 80% (non-condensing) |
