Samsung S32D850T 32" 2560 x 1440 5ms HDMI LED Monitor
£399.15
39 in stock
Delivery:
Standard: 1-3 working days
Key features
  • Business monitor
  • Seamless multi-screen functionality
  • Diagonal Size: 32in
  • Max Resolution: 2560 x 1440
  • Response Time: 5ms
  • Speakers: None
  • Interfaces: DisplayPort, DVI, HDMI
Product codes
The SD850 has 2560 x 1440 wide quad high-definition (WQHD) resolution, twice that of Full HD, with a 178° viewing angle. The monitor can display over one billion colors, incorporating 100 per cent of the sRGB color space. Its approximate 3.7 million pixels offer deep and rich image detail for a more realistic picture. Aimed at content creaters, programmers and those in financial services, the monitor can not only display picture-in-picture in 720p, but also picture-by-picture to display images from two separate sources, such as a laptop and a desktop PC.
The SD850 has an eco light sensor that adapts the brightness of the monitor dynamically according to available light to save power. The monitor also has an Energy Star rating of 6.0 to ensure efficiency. The materials that make up the SD850 have also been TCO Certified.
Product Description Samsung S32D850T - SD850 Series - LED monitor - 32"
Device Type LED-backlit LCD monitor - 32"
Energy Class Class B
Energy Consumption per Year 82 kWh
Power Consumption (On mode) 56 W
Features USB 3.0 hub
Panel Type MVA
Aspect Ratio 16:9
Native Resolution 2560 x 1440
Pixel Pitch 0.27675 mm
Brightness 300 cd/m²
Contrast Ratio 3000:1
Response Time 5 ms (grey-to-grey)
Colour Support 1 billion colours
Input Connectors HDMI, DVI, DisplayPort
Display Position Adjustments Height, pivot (rotation), swivel, tilt
Colour Titanium silver, matte black
Dimensions (WxDxH) - with stand 74.13 cm x 28 cm x 50 cm
Weight 12.2 kg
Compliant Standards UL, TUV, VCCI, C-Tick, EN55022, EN55024, CB, CCC, PSB, AS/NZS 3548, KCC, FCC Part 15 B Class A, KC, GB 9254-2008, GB 17625.1-2003 EMC, KN22, KN24
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
Samsung S32D850T 32" 2...
£399.15
