Ultra-WQHD resolution with 34" curved display Immerse yourself in detail. Within games, movies or design projects, surround yourself with the 34" ultra-wide curved display featuring a 21:9 aspect ratio. Ultra-WQHD provides the simplest way to maximise your screen real estate and experience truly seamless multitasking on just one screen.
Enhanced concentration and comfort Enhance productivity and reduce eye strain for those long working days. 1000R curvature closely matches the curve of the human field of sight, allowing content to be viewed at a glance while proven to effectively limit eye strain compared with flat monitors for a more comfortable experience.
Enjoy a billion colours with incredible depth 1 billion colours with HDR 10 Enjoy any content in stunning colour accuracy and detail. With a wide range of colours, near limitless hues and HDR10, which makes dark colours darker and the brightest colours even brighter, every piece of content becomes a joy to look at and can be experienced exactly as the creator intended.
USB Type-C with LAN Port Ditch the clutter and keep connected. S6 features a USB Type-C port with 90W charging to power your laptop and transmit data with just one cable. It also has a LAN Port which allows a laptop that has no LAN port to simply connect to the monitor for Ethernet use.
Fast 100 Hz refresh rate The fast 100 Hz screen refresh rate provides smoother, silkier mouse sensitivity for enhanced productivity in any application. It also reduces screen stutter in fast-moving action scenes for a flawless gaming experience.
Product Description | Samsung S34A650UXU - LED monitor - curved - 34" | Device Type | LED-backlit LCD monitor - 34" | Energy Class | Class G | Energy Consumption per Year | 51 kWh | Power Consumption (On mode) | 35 W | Curved Screen | Yes | Features | USB 3.0/USB-C hub, Ethernet network adapter | Panel Type | VA | Aspect Ratio | 21:9 | Native Resolution | UWQHD 3440 x 1440 at 100 Hz | Brightness | 300 cd/m² | Contrast Ratio | 4000:1 | Response Time | 5 ms | Colour Support | 1.07 billion colours | Input Connectors | HDMI, DisplayPort, USB-C | Display Position Adjustments | Height, pivot (rotation), swivel, tilt | Voltage | AC 120/230 V | Colour | Black | Dimensions (WxDxH) - with stand | 80.66 cm x 23.49 cm x 55.33 cm | Weight | 7.6 kg |
General | |
Display Type | LED-backlit LCD monitor / TFT active matrix |
Energy Class (HDR) | Class G |
Diagonal Size | 34" |
Curved Screen | Yes (1000R) |
Built-in Devices | USB 3.0/USB-C hub, Ethernet network adapter |
Panel Type | VA |
Horizontal Viewing Angle | 178 |
Vertical Viewing Angle | 178 |
Backlight Technology | LED backlight |
Features | Picture by picture, game mode, Eco Light Sensor, Mega Infinity Dynamic Contrast Ratio, Flicker Free technology, Image Size, Eco Saving Plus, Eye Saver Mode, FreeSync Technology, Off Timer Plus, Picture-in-Picture, Adaptive Picture, Auto Source Switch |
Colour | Black |
Dimensions (WxDxH) | 80.66 cm x 23.49 cm x 55.33 cm - with stand |
Weight | 7.6 kg |
Connectivity | |
Interfaces | DisplayPort 1.2 , HDMI , Headphones , 3 x USB 3.0 , USB-C (power up to 90W) , Network |
Mechanical | |
Tilt Angle | -2/+25 |
Swivel Angle | 60 |
Height Adjustment | 120 mm |
VESA Mounting Interface | 100 x 100 mm |
Miscellaneous | |
Features | Security lock slot (cable lock sold separately) |
Cables Included | 1 x HDMI cable , 1 x USB-C cable |
Security Slot Type | Kensington security slot |
Power | |
Input Voltage | AC 120/230 V |
Power Consumption SDR (On mode) | 35 kWh/1000h |
Power Consumption HDR (On mode) | 38 kWh/1000h |
Power Consumption (Typical) | 35 Watt |
Dimensions & Weight | |
Dimensions & Weight Details | With stand - width: 80.66 cm - depth: 23.49 cm - height: 55.33 cm - weight: 7.6 kg , Without stand - width: 80.66 cm - depth: 12.81 cm - height: 36.94 cm - weight: 5.1 kg |
Dimensions & Weight (Shipping) | |
Shipping Width | 89.5 cm |
Shipping Depth | 21.6 cm |
Shipping Height | 47.1 cm |
Shipping Weight | 9.7 kg |
Environmental Parameters | |
Min Operating Temperature | 10 °C |
Max Operating Temperature | 40 °C |
Humidity Range Operating | 10 - 80% (non-condensing) |
To help you find items available at this time, we’re only showing items we have in stock to avoid backorders. Pop your email address below and we’ll let you know when this item is back in stock:
