Samsung S34J550WQU 34.1" 3440x1440 4ms HDMI LED Monitor
£401.26
24 in stock
Delivery:
Standard: 1-3 working days
Key features
  • All-around performer
  • Superior image quality
  • Stylish and practical
  • Smoother gameplay
  • Diagonal Size: 34.1in
  • Max Resolution: 3440 x 1440
  • Response Time: 4ms
  • Speakers: None
  • Interfaces: DisplayPort, HDMI
Product codes
With its ultra-wide screen and high resolution, the SJ55W provides all the workspace you need to comfortably multitask on a single screen. And whether you're working on documents, playing games, or watching movies, you'll enjoy all your content in superbly detailed quality.
Product Description Samsung LS34J550WQU - SJ55W Series - LED monitor - 34.1"
Device Type LED-backlit LCD monitor - 34.1"
Energy Class Class A
Energy Consumption per Year 51 kWh
Power Consumption (On mode) 35 W
Adaptive-Sync Technology AMD FreeSync
Panel Type VA
Aspect Ratio 21:9
Native Resolution Ultra WQHD 3440 x 1440 at 60 Hz
Brightness 300 cd/m²
Contrast Ratio 3000:1
Response Time 4 ms (grey-to-grey)
Colour Support 16.7 million colours
Input Connectors 2xHDMI, DisplayPort
Display Position Adjustments Tilt
Colour Dark grey/blue
Dimensions (WxDxH) - with stand 82.81 cm x 24.28 cm x 47.08 cm
Weight 6.9 kg
Compliant Standards DisplayPort 1.2
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
Samsung S34J550WQU 34....
£401.26
