Samsung Smart Home Camera HD Outdoor
Key features
  • High resolution video
  • Wide angle
  • Motion zone detection
  • Saving in the memory card
  • Easy installation
  • Real-time alarm
  • Bi-directional audio
  • Night vision (5m)
  • Clear color
  • Installable outside
  • Main KeySellingPoints/camera detachable design
Product codes
2M (Full HD) SNH-E6440Bn camera helps you to monitor a clearer and brighter video. The visual angle of 128 degrees can provide wide monitoring coverage for your camera. If you set a specific area such as entrance or windows, it can monitor movements and send alerts about that area.
You can save your important moments in the memory card. A max 32GB memory card may be used. The recorded video can be played using your smart phone or PC viewer anytime anywhere.
It supports the Wi-Fi direct function that allows you to connect your camera to the wireless network.
Using your smartphone and SmartCam you can chat with your friends due to the built in mic/speaker units in the SmartCam.
The product is water/vibration proof (IP66), and it can be installed in an outdoor area or outside the home.
Samsung Techwin SmartCam SNH-E6440BN - network surveillance camera
Network surveillance camera - fixed - outdoor - waterproof
Audio
Yes: two-way audio capability
5.4 cm x 5.4 cm x 10.2 cm
568 g
White
Wired, wireless
Camera
Colour - Day&Night
Max Resolution
1920 x 1080
Frame Rate (max)
30 frames per second
Motion Detection
Video Modes
1080p
Optical Sensor Type
CMOS - 1/2.8" - 2 MP
Minimum Illumination
0 lux - B&W , 0.3 lux - colour
Focal Length Control
Fixed focal
Focal Length
2.8 mm
Ethernet 10Base-T/100Base-TX, IEEE 802.11b, IEEE 802.11g, IEEE 802.11n
1 - network cable - external
Voltage
DC 9 V
Alarm function, progressive scanning, image flip, image mirror, Motion Detection Technology, multi-streaming, Intelligent Video Analysis (IVA), Audio Detection, Motion Zone Alert, auto white balance, Wi-Fi Direct
Environmental Parameters (operating)
-10 °C - 50 °C; 0 - 90% relative humidity
Customer reviews
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
Samsung Smart Home Cam...
