Samsung Smart Home PoE Outdoor Cam
Key features
  • 1080p Full HD resolution
  • Weather-resistant housing
  • Easy installation with PoE adapter
  • 130° ultra-wide angle lens
  • Night vision to 15m
Product codes
2M (Full HD)Samsung Techwin SmartCam helps you to monitor a clearer and brighter video. The visual angle of 128 degrees can provide wide monitoring coverage for your camera. If you set a specific area such as entrance or windows, it can monitor movements and send alerts about that area. In poorly lit areas, the IR LED is operated automatically to brighten dark images. IR Cut filter switches between day and night to provide clearer color images.
Samsung SmartCam SNH-V6430BNH - network surveillance camera
Network surveillance camera - fixed - outdoor - weatherproof
Audio
Yes: built-in microphone
7.8 cm x 7.8 cm x 7.11 cm
271 g
White
Wired, wireless
Camera
Colour - Day&Night
Max Resolution
1920 x 1080
Motion Detection
Video Modes
1080p
Optical Sensor Type
CMOS - 1/3"
Minimum Illumination
0.3 lux - colour , 0 lux - B&W
Focal Length Control
Fixed focal
Focal Length
2.8 mm
IEEE 802.11b, Ethernet 10Base-T, IEEE 802.11g, IEEE 802.11n, IEEE 802.11a, IEEE 802.11ac
1 - network cable - external - 10 m
Voltage
PoE Class 3
Progressive scanning, image flip, image mirror, Wide Dynamic Range (WDR), 2D Noise Reduction Technology, Motion Detection Technology, Lens Distortion Correction, 3D Noise Filtering, High Dynamic Range (HDR), Audio Detection, auto white balance, Motion Zone Select
Environmental Parameters (operating)
-30 °C - 40 °C; 0 - 90% relative humidity
Customer reviews
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
Samsung Smart Home PoE...
