Samsung SmartThings Motion Sensor (2018)
FREE DELIVERY
£24.00
20 in stock
Delivery:
Standard: 1-3 working days
Key features
  • Video capability
  • Simple set-up
  • Type: Motion sensor
  • Compatible With: Alexa, Google Assistant, SmartThings
  • Stock Status: In Stock
Product codes
Bundle deals (1)
BUY TWO SAMSUNG SMARTTHINGS MOTION SENSORS AND SAVE!
= £42.99
Save £5.00
Know when there’s movement in your home.
  • Know when there’s movement in your home.
  • Receive alerts if there’s unexpected movement.
  • Set connected devices to turn on and off as people come and go.
  • Adjust the sensor angle with the magnetic ball mount.
  • Requires a SmartThings Hub or compatible device with SmartThings Hub functionality. http://www.shop.bt.com/DS2N
Add smartness to your home with a SmartThings Motion Sensor. Receive alerts if there’s unexpected movement, set connected devices to turn on and off as people come and go, and much more. Also monitors temperature. Requires a SmartThings Hub or compatible device with SmartThings Hub functionality. Connected devices sold separately.
SmartThings is the easy way to turn your home into a smart home.
  • Your smart home needs a brain, so get started with SmartThings. It connects wirelessly with a wide range of smart devices and makes them work together.
  • Next, add some smart devices and put your home to work. Choose from a wide range of compatible devices, including lights, cameras, locks, thermostats, sensors, and more.
  • Finally, use the Google Assistant, Amazon Alexa, or the SmartThings app to control your smart home. Teach your house new tricks by telling it what to do when you’re asleep, awake, away, and back home.
In the Box
  • SmartThings Motion Sensor.
  • Battery, magnetic ball mount, and wall-mounting pads.
  • Quick-start guide and health and safety guide.
Requirements
  • Requires the free SmartThings app for Android (6.0 or later) or iOS (10.0 or later).
  • Visit SmartThings.com for specifications, support, and more.
Technical Information
  • Power: 1 x CR2 battery.
  • Communication Protocol: Zigbee.
  • Range: 15-40 meters depending on your home’s construction.
  • Operating Temperature: 0 to 40°F.
  • Range: Detects motion up to 4.6 meters with a 120° view
  • Dimensions: 56.6 x 55.6 x 50.3 mm.
  • Weight: 95.3 grams
  • Color: White.
  • Warranty: One-year limited warranty.
Product Description Samsung SmartThings - motion sensor
Product Type Motion sensor
Functions Motion detection
Power Source Battery
Internet of Things (IoT) Platform SmartThings
Connectivity Wireless - ZigBee 3.0
Colour White
Manufacturer Warranty 1-year warranty
Dimensions (WxDxH) 5.66 cm x 5.02 cm x 5.57 cm
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
Samsung SmartThings Mo...
£24.00
