Samsung SmartThings Smart Button (2018)
FREE DELIVERY
£24.00
40 in stock
Delivery:
Standard: 1-3 working days
Express: Delivered on Tuesday
Express Delivery:
  • 00 h
  • 00 m
  • 00 s
Key features
  • Video capability
  • Simple set-up
  • Type: Push button
  • Compatible With: Alexa, Google Assistant, SmartThings
  • Stock Status: In Stock
Product codes
Control connected devices at the touch of a button.
  • Control lights, electronics, and small appliances.
  • Set multiple lights, electronics, and small appliances to turn on and off with the button.
  • Customize actions with a single tap, double tap, or long press.
  • Requires a SmartThings Hub or compatible device with SmartThings Hub functionality. https://www.shop.bt.com/DS2N
Add smartness to your home with a SmartThings Button. Control lights, electronics, and small appliances at the touch of a button. Also monitors temperature.
SmartThings is the easy way to turn your home into a smart home.
  • Your smart home needs a brain, so get started with SmartThings. It connects wirelessly with a wide range of smart devices and makes them work together.
  • Next, add some smart devices and put your home to work. Choose from a wide range of compatible devices, including lights, cameras, locks, thermostats, sensors, and more.
  • Finally, use the Google Assistant, Amazon Alexa, or one of the SmartThings apps to control your smart home. Teach your house new tricks by telling it what to do when you’re asleep, awake, away, and back home
In the Box
  • SmartThings Button.
  • Quick-start guide and health and safety guide.
Requirements
  • Requires the free SmartThings app for Android (6.0 or later) or iOS (10.0 or later).
  • Visit SmartThings.com for specifications, support, and more.
Technical Information
  • Power: 1 x CR2450 battery.
  • Communication Protocol: Zigbee.
  • Range: 15-40 meters depending on your home’s construction.
  • Operating Temperature: 0 to 40°C.
  • Dimensions: 40.9 x 40.9 x 14.7 mm.
  • Weight: 22.7 grams.
  • Color: White.
  • Warranty: One-year limited warranty.
Product Description Samsung SmartThings - push button
Product Type Push button
Functions Turn electronics on/off
Power Source Battery
Internet of Things (IoT) Platform SmartThings
Connectivity Wireless - ZigBee 3.0
Colour White
Manufacturer Warranty 1-year warranty
Dimensions (WxDxH) 4.08 cm x 1.48 cm x 4.08 cm
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
Samsung SmartThings Sm...
£24.00
