Samsung SRP-770ii LIGHT GREY USB SERIA
Product codes
BIXOLON SRP-770II is the first label printer developed with the technological power of Samsung, which has been proved in the POS printer market. The SRP-770II can print 5ips(127mm/sec) and can recognize various programming languages such as SLCS, BPL-Z, BPL-E automatically, and also the width of the paper can be adjusted easily to the range of 1.5~4.2 inch so that it can be used for barcode printing as well as receipt printing. The various on-board interfaces including Serial, Parallel, and USB allow flexible system configuration.
  • Fast printing speed 5ips(127 mm/sec)
  • High resolution of printing(203 dpi)
  • Wide label width from 1.5 ~4.2 inch
  • All-in-one Interface - Standard: Serial+USB 2.0+Parallel
Specification
Print Characteristics
  • Printing Method: Direct Thermal
  • Printing Speed: Up to 5 ips (127 mm/s)
  • Print Resolution: 203 dpi
  • Printing Width: Up to 104 mm
  • Printing Length: 6 ~ 304 mm
  • Media Sensor: Transmissive, Reflective, Head open
Media Characteristics
  • Media Type: Gap, Black Mark, Notch, Continuous, Fan-Fold
  • Media Width: 42 ~ 106 mm
  • Media Roll Diameter: Up to 130 mm
  • Media Thickness: 0.06 ~ 0.20 mm
  • Supply Method: Easy Paper Loading
Physical Characteristics
  • Dimensions (W x L x H): 184 x 221 x 171 mm (7.24 x 8.70 x 6.73 inch)
  • Weight: 1.65 kg (3.63 lbs.)
  • Power: External Power Adaptor 100-240V AC, 50/60Hz
Performance Characteristics
  • Memory: 512KB SRAM, 2MB FlashROM
  • Interface: Triple Interface
  • Standard: Serial+Parallel+USB V1.1 FS
  • Optional: Parallel+Ethernet+USB V1.1 FS
Environment Characteristics
  • Temperature: Operating: 0 ~ 40 °C (32 ~ 104 °F) / Storage: -20 ~ 60 °C (-4 ~ 140 °F)
  • Humidity: Operating: 10 ~ 80% RH / Storage: 10 ~ 90% RH
Software
  • Emulation: SLCS, BPL-Z™, BPL-E™
  • Driver / Utility: Windows Driver, Linux CUPS Driver, Mac Driver, Virtual
  • COM USB/Ethernet Driver, Utility Program, Label Artist™
  • SDK: Android SDK
Fonts / Graphics / Symbologies
  • Character Sets: - 10 SLCS Resident Bitmap Fonts
  • One SLCS Resident Scalable Font
  • 23 Code Page
  • Graphics: Supporting user-defined fonts, graphics, formats, and logos
  • Barcode Symbologies: 1D: Coda Bar, Code39, Code93, EAN-8, EAN-13, Interleaved 2-of-5, ITF, UCC/EAN-128, UPC-A, UPC-E 2D: Data Matrix, MaxiCode, PDF417, QR Code (select two only)
  • Options: Ethernet, Auto Cutter
Customer reviews
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
Samsung SRP-770ii LIGH...
