Light and pocket-sized, the Portable SSD T7 both delivers fast speeds and safeguards data for an easy way to store and transfer large files. Experience everyday high performance in your work and play with the T7.
Product Description | Samsung T7 MU-PC2T0R - SSD - 2 TB - USB 3.2 Gen 2 | Type | Solid state drive - external (portable) | Capacity | 2 TB | Hardware Encryption | Yes | Encryption Algorithm | 256-bit AES | Interface | USB 3.2 Gen 2 - USB-C | Data Transfer Rate | 10.0 Gbps (USB 3.2 Gen2) | Features | Shock resistant, password authentication, Dynamic Thermal Guard protection, NVM Express (NVMe), 256-bit AES | Power Source | USB bus | Enclosure Colour | Red metallic | Dimensions (WxDxH) | 85 mm x 8 mm x 57 mm | Weight | 58 g | Manufacturer Warranty | 3-year warranty |
General | |
Device Type | Solid state drive - external (portable) |
Capacity | 2 TB |
Interface | USB 3.2 Gen 2 |
Width | 85 mm |
Depth | 8 mm |
Height | 57 mm |
Weight | 58 g |
Performance | |
Interface Transfer Rate | 10.0 Gbps (USB 3.2 Gen2) |
Max Data Transfer Rate | 1050 MB/s |
Internal Data Rate | 1050 MBps (read) / 1000 MBps (write) |
Expansion & Connectivity | |
Interfaces | 1 x USB 3.2 Gen 2 - 24 pin USB-C |
Power | |
Software & System Requirements | |
OS Required | Microsoft Windows 7 or later, Apple MacOS X 10.10.x or later, Android 5.1 (Lollipop) or later |
Miscellaneous | |
Cables Included | 1 x USB-C cable , 1 x USB-C to USB-A cable |
Compliant Standards | UL, TUV, VCCI, C-Tick, BSMI, CB, IC, FCC, KC, RoHS2, EAC, UASP (USB Attached SCSI Protocol) |
Manufacturer Warranty | |
Service & Support | Limited warranty - 3 years |
To help you find items available at this time, we’re only showing items we have in stock to avoid backorders. Pop your email address below and we’ll let you know when this item is back in stock:
