Samsung U28H750 28" QLED UHD Monitor
£329.00
Delivery:
Key features
  • Colorfully expressive
  • PBP dual-screen function
  • PIP sub-screen display
  • Slim KeySellingPoints, thin bezels
  • Diagonal Size: 28in
  • Max Resolution: 3840 x 2160
  • Response Time: 1ms
  • Speakers: None
  • Interfaces: DisplayPort, HDMI
Product codes
Blending infinitesimal quantum dots with billions of hues, the UH75 restores images in their true colors, vividly and accurately. Especially with greens and reds refreshingly freed from desaturation, what you see on the screen simply comes alive as if unmediated by a screen. Samsung's Picture-by-Picture capabilities let you connect to two different devices at the same time while still maintaining the original image quality. The Picture-in-Picture feature allows you to do away with the need for a second monitor even when you are multitasking. You can resize the second image and position it anywhere you wish. Slim-bodied with narrow bezels and its sleek back, the UH75 in short is a performance in beauty. Its urbane, modern appeal will seamlessly blend in with any décor of your choice.
Product Description Samsung U28H750UQU - UH75 Series - LED monitor - 4K - 28"
Device Type LED-backlit LCD monitor - 28"
Energy Class Class B
Energy Consumption per Year 50 kWh
Power Consumption (On mode) 34 W
Adaptive-Sync Technology AMD FreeSync
Panel Type TN
Aspect Ratio 16:9
Native Resolution 4K 3840 x 2160 at 60 Hz
Brightness 300 cd/m²
Contrast Ratio 1000:1
Response Time 1 ms (grey-to-grey)
Colour Support 1.07 billion colours
Input Connectors 2xHDMI, DisplayPort
Display Position Adjustments Tilt
Colour Black, silver
Dimensions (WxDxH) - with stand 65.37 cm x 24.28 cm x 47.63 cm
Weight 5.2 kg
Environmental Standards ENERGY STAR Qualified
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
Samsung U28H750 28" QL...
£329.00
