Samsung U32H850UMU 31.5" 3840x2160 4ms HDMI DP MiniDP LE...
Samsung U32H850UMU 31.5" 3840x2160 4ms HDMI DP MiniDP LED Monitor
£499.99
15 in stock
Delivery:
Standard: 1-3 working days
Key features
  • Ultra high clarity
  • Quantum dots in 1B hues
  • PBP dual-screen function
  • PIP sub-screen display
  • Ergonomic design
  • Slim KeySellingPoints, thin bezels
  • Multiple USB 3.0 ports
  • Diagonal Size: 32in
  • Max Resolution: 3840 x 2160
  • Response Time: 4ms
  • Speakers: None
  • Interfaces: DisplayPort, HDMI, Mini DisplayPort
Product codes
Bundle deals (3)
SAMSUNG GALAXY BUDS+
= £628.99
Save £30.00
SAMSUNG GALAXY BUDS - BLACK
= £613.99
Save £25.00
ANTIBACTERIAL WIPES
ANTIBACTERIAL WIPES
= £503.48
Save £1.50
The UH85 has a resolution 4 times higher than Full HD. Its wider workspace allows you to view more webpages, images and texts with less scrolling and zooming. Also, see your 4K content the way it was meant to be seen, with a new level of life-like detail that makes you feel like you're really there.
The UH85's infinitesimal quantum dots in 1 billion hues create images in vivid and wide-ranging colors. Coming with refreshingly enriched greens and reds in particular, it simply better meets your professional needs especially in photo editing and graphic design.
Product Description Samsung U32H850UMU - UH85 Series - LED monitor - 4K - 32"
Device Type LED-backlit LCD monitor - 32"
Energy Class Class C
Energy Consumption per Year 89 kWh
Power Consumption (On mode) 61 W
Adaptive-Sync Technology AMD FreeSync
Features USB 3.0 hub
Panel Type VA
Aspect Ratio 16:9
Native Resolution 4K 3840 x 2160 at 60 Hz
Brightness 250 cd/m²
Contrast Ratio 3000:1
Response Time 4 ms (grey-to-grey)
Colour Support 1.07 billion colours
Input Connectors 2xHDMI, DisplayPort, Mini DisplayPort
Display Position Adjustments Height, pivot (rotation), swivel, tilt
Colour Black, silver
Dimensions (WxDxH) - with stand 73.11 cm x 29.86 cm x 62 cm
Weight 8.8 kg
Environmental Standards ENERGY STAR Qualified
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
Samsung U32H850UMU 31....
£499.99
