Sandisk 240GB Ultra II SATA 6GB/s 2.5" Solid State Drive
BOOST YOUR PC'S PERFORMANCE BY UP TO 28X
Key features
  • Up to 25x faster than a typical hard drive for improved productivity at work and at play
  • nCache 2.0 technology delivers advanced speeds and endurance
  • No-wait boot up and shut down saves you time
  • Double your drive reliability so you can work hard and game hard in confidence
  • Cool, quiet and power efficient with a longer battery life
Product codes
Boost your PC's performance by up to 28x with an easy and affordable upgrade to SanDisk Ultra II SSD. You'll enjoy no-wait boot up, and shorter application load and data transfer times than your traditional hard drive ever delivered – plus longer battery life and much cooler, quieter computing, too1. No matter how you use your PC, SanDisk's nCache 2.0 technology makes for a better experience, delivering high speed and staying power, even when you're socialising, shopping and watching the football, all at once. Proven shock and vibration resistance means you won't lose your data even if you drop your computer. When you're ready for a better computing experience without buying a new computer, this easy-to-do-yourself upgrade to SanDisk Ultra II SSD will make your old PC behave like a brand-new machine.
SanDisk Ultra II - solid state drive - 240 GB - SATA 6Gb/s
Solid state drive - internal
240 GB
2.5"
SATA 6Gb/s
Data Transfer Rate
600 MBps
69.85 mm x 100.5 mm x 7 mm
North America
Microsoft Certification
Compatible with Windows 7
3-year warranty
Customer reviews
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
Sandisk 240GB Ultra II...
