The SanDisk Ultra Flair USB 3.0 flash drive moves your files fast. Spend less time waiting to transfer files and enjoy high-speed USB 3.0 performance of up to 150MB/s1. Its durable and sleek metal casing is tough enough to handle knocks with style. And, with password protection, you can rest assured that your private files stay private2. Store your files in style with the SanDisk Ultra Flair USB 3.0 flash drive.
Product Description | SanDisk Ultra Flair - USB flash drive - 256 GB | Product Type | USB flash drive | Interface Type | USB 3.0 | Storage Capacity | 256 GB | Encryption Algorithm | 128-bit AES | Localisation | Latin America, Asia Pacific, Middle East, Africa, Europe | Software Included | SanDisk SecureAccess 3.0 | OS Required | Apple MacOS X 10.6 or later, Microsoft Windows Vista / 7 / 8 / 10 | Manufacturer Warranty | 5-year warranty |
General | |
Memory | |
Read Rate | Up to 150 MB/s |
Features | Password protection, metal body |
Software / System Requirements | |
Manufacturer Warranty | |
Service & Support | Limited warranty - 5 years |
Dimensions & Weight | |
Width | 13.21 mm |
Depth | 42.42 mm |
Height | 6.6 mm |
Environmental Parameters | |
Min Operating Temperature | 0 °C |
Max Operating Temperature | 45 °C |
To help you find items available at this time, we’re only showing items we have in stock to avoid backorders. Pop your email address below and we’ll let you know when this item is back in stock:
