Sandisk 2TB Ultra 3D 2.5" SATA 6Gb/s SSD
Delivery:
Standard: 1-3 working days
Key features
  • Accelerated performance for faster boot-up, shut-down, and app response
  • Ultra-fast: sequential read speeds of up to 560MB/s; sequential write speeds of up to 530MB/s
  • Ultra-fast: sequential read 550MB/s; sequential write 525MB/s [250GB ONLY]
  • 3D NAND provides greater endurance so your drive lasts longer and uses less power
  • nCache 2.0 technology delivers blazing-fast speeds
  • 3-year warranty or 100TBW, whichever is sooner
  • 3-year warranty or 200TBW, whichever is sooner
  • 3-year warranty or 400TBW, whichever is sooner
  • 3-year warranty or 500TBW, whichever is sooner
  • Form Factor: 2.5"
  • Capacity: 2TB, 2TB
  • Interface: Serial ATA-600
  • Type: Internal hard drive
  • Stock Status: In Stock
Product codes
Get accelerated performance for better gaming and pro-level multitasking with graphics-intensive apps. Powered by 3D NAND technology, the SanDisk Ultra 3D SSD delivers enhanced endurance and reliability, blazing sequential read speeds of up to 560MB/s [550MB/s: 250GB ONLY] and sequential write speeds of up to 530MB/s [550MB/s: 250GB ONLY] for no-wait boot-up, shorter application load times, and quicker data transfer . In addition to cooler, quieter computing, the SanDisk Ultra 3D SSD includes proven shock and vibration-resistance to protect your drive. From the company that invented the solid state technology that makes SSDs possible, the SanDisk Ultra 3D SSD catapults your performance to new levels.SanDisk products are constructed to the highest standards and rigorously tested. You can be confident in the outstanding quality, performance and reliability of every SanDisk product.
Product Description SanDisk Ultra 3D - solid state drive - 2 TB - SATA 6Gb/s
Type Solid state drive - internal - nCache 2.0 technology, 3D NAND Technology
Capacity 2 TB
Form Factor 2.5"
Interface SATA 6Gb/s
Data Transfer Rate 600 MBps
Features nCache 2.0 technology, 3D NAND Technology
Dimensions (WxDxH) 69.95 mm x 100.5 mm x 7 mm
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
Sandisk 2TB Ultra 3D 2...
£293.73
