Sandisk Cruzer Blade - USB flash drive - 16 GB - Hi-Speed USB
£4.40
37 in stock
Delivery:
Standard: 1-3 working days
Key features
  • Compact, light design makes it easy to carry round
  • The easiest way to share, store and protect your music, pictures, videos and work
  • So simple to use, you can be up and running in seconds
  • SanDisk SecureAccess software protects private files with a personal password and automatic 128-bit AES encryption
  • It couldn't be easier to use: simply drag and drop files into a private folder or "vault" and they're safe
  • Capacity: 16GB
  • Interface: USB 2.0
  • Stock Status: In Stock
Product codes
The 16GB Cruzer Blade USB Flash Drive may look small, but it has all the space you need to store and share tunes, pictures and home videos – or your presentations and spreadsheets – whenever you want. Despite storing 16GB in a compact and contoured design, the Cruzer Blade USB Flash Drive is barely half the size of most USB Flash Drives. It makes sure that your private files stay protected, with the password protection  and encryption offered by SanDisk SecureAccess software.
Product Description SanDisk Cruzer Blade - USB flash drive - 16 GB
Product Type USB flash drive
Interface Type USB 2.0
Storage Capacity 16 GB
Microsoft Certification Compatible with Windows 7
Manufacturer Warranty 5-year warranty
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
Sandisk Cruzer Blade -...
£4.40
