Sandisk Cruzer Blade USB FlashDrive 64GB
£12.10
Hurry, only 1 left in stock!
Delivery:
Standard: 1-3 working days
Express: Delivered on Wednesday
Express Delivery:
  • 00 h
  • 00 m
  • 00 s
Key features
  • Compact, light design makes it easy to carry round
  • The easiest way to share, store and protect your music, pictures, videos and work
  • So simple to use, you can be up and running in seconds
  • SanDisk SecureAccess software protects private files with a personal password and automatic 128-bit AES encryption
  • It couldn't be easier to use: simply drag and drop files into a private folder or "vault" and they're safe
  • Capacity: 64GB
  • Interface: USB 2.0
  • Stock Status: Clearance
Product codes
The 64GB Cruzer Blade USB Flash Drive may look small, but it has all the space you need to store and share tunes, pictures and home videos – or your presentations and spreadsheets – whenever you want. Despite storing 64GB in a compact and contoured design, the Cruzer Blade USB Flash Drive is barely half the size of most USB Flash Drives. It makes sure that your private files stay protected, with the password protection and encryption  offered by SanDisk SecureAccess software.
Product Description SanDisk Cruzer Blade - USB flash drive - 64 GB
Product Type USB flash drive
Interface Type USB 2.0
Storage Capacity 64 GB
Encryption Algorithm 128-bit AES
Enclosure Colour Black, red
Localisation Latin America, Asia Pacific, Middle East, Africa, Europe
Software Included SanDisk SecureAccess
OS Required Microsoft Windows Vista / XP / 7, Apple MacOS X 10.5 or later
Microsoft Certification Compatible with Windows 7
Manufacturer Warranty 5-year warranty
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
Sandisk Cruzer Blade U...
£12.10
