SanDisk Cruzer Fit - USB flash drive - 32 GB - USB 2.0
£7.26
Hurry, only 3 left in stock!
Delivery:
Standard: 1-3 working days
Key features
  • Low profile design is perfect for tablets, car stereos and other small devices
  • Fits so neatly into USB slots that it's less likely to get damaged
  • SanDisk SecureAccess software protects private files with a personal password and automatic 128-bit AES encryption
  • It couldn't be easier to use: simply drag-and-drop files into a private folder or 'vault' and they're safe
  • Capacity: 32GB
  • Interface: USB 2.0
  • Stock Status: In Stock
Product codes
Plug In and Leave On for Unobtrusive File Transfer
With its advanced data security options and spacious capacity, the Cruzer Fit USB Flash Drive gives you a secure, easy way to transfer your personal files. This USB drive features a convenient low-profile design that's ideal for situations where a full-size USB drive is just too big, such as use with a TV or car audio device. The Cruzer Fit USB also connects easily to computers and tablets.
Low-profile design for easy USB connectivity
Store all your most important data with 32GB capacity
SanDisk SecureAccess™ software provides password protection
Includes up to 2GB of online backup optionally available from YuuWaa
Fits unobtrusively in a tablet or car audio USB port
Low-Profile Form Factor for Easy Connections
The drive's low-profile design allows it to easily connect to any USB device. Connect it to hard-to-access TV USB ports for HD video play back or bring your entire music library to your car via the USB port on your vehicle's audio system. The flash drive comes with a protective cap, which shields the USB connector from damage when not in use.
High-Capacity Drive Holds Music, Video, Photos, and Personal Files
Despite its compact size, the Cruzer Fit USB flash drive packs enough capacity for your favorite files and your most critical personal data. Available in 32GB, the drive can accommodate photos, songs, and whatever else you need to carry.
Add Files Easily with Drag-and-Drop File Loading
It's easy to add files to the Cruzer Fit USB flash drive: just plug the USB drive into your computer's USB port and drag your files into the drive's folder. You don't need to download drivers or install software to use it, so you can start storing, transporting, and sharing your data immediately.
SanDisk SecureAccessSoftware Protects Your Private Files
The Cruzer Fit USB flash drive comes with SanDisk SecureAccess, which creates a password-protected private folder on your flash drive. With your private files protected with 128-bit AES encryption, you'll be able to share your USB drive without compromising your privacy.
Includes 2GB of Cloud Storage offered by YuuWaa
The Cruzer Fit USB flash drive also comes with the added protection of secure online backup (up to 2 GB optionally available) offered byYuuWaa™, a cloud storage service. Using a user-friendly drag-and-drop interface that syncs with your USB drive, the Cruzer Fit USB flash drive lets you easily transfer files to a secure YuuWaa server for safe online backup.
Product Description SanDisk Cruzer Fit - USB flash drive - 32 GB
Product Type USB flash drive
Interface Type USB 2.0
Storage Capacity 32 GB
Encryption Algorithm 128-bit AES
Software Included SanDisk SecureAccess
OS Required Microsoft Windows Vista / XP / 7, Apple MacOS X 10.5 or later
Microsoft Certification Compatible with Windows 7
Manufacturer Warranty 5-year warranty (regions not recognising "limited" warranty - 5 years)
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
SanDisk Cruzer Fit - U...
£7.26
