Sandisk Extreme Pro Micro SD 32GB
£79.29
16 in stock
Delivery:
Standard: 1-3 working days
Key features
  • RescuePRO Deluxe data recovery software download offer
  • Jewel case for protective storage and archiving
  • Lifetime warranty
  • Lifetime limited warranty (US only)
  • Type: microSDXC UHS-II Memory Card
  • Capacity: 64GB
  • SD Speed Class: UHS Class 3 / Class10
  • Stock Status: In Stock
Product codes
With the SanDisk Extreme PRO microSDXC UHS-II Card, you can now get to your videos faster than ever before. Use the included USB 3.0 reader for convenient transfers and take the bottleneck out of enjoying even your most massive 4K UHD video files . Finally your memory card can keep up with you and your lifestyle! From a leader in flash memory storage, this card is ideal for offloading 4K UHD video from your action camera, drone, high-performance camera or smartphone.SanDisk products are constructed to the highest standards and rigorously tested. You can be confident in the outstanding quality, performance and reliability of every SanDisk product.
Product Description SanDisk Extreme Pro - flash memory card - 64 GB - microSDXC UHS-II
Product Type Flash memory card
Form Factor microSDXC UHS-II Memory Card
Storage Capacity 64 GB
Speed Rating UHS Class 3 / Class10
Localisation Canada
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
Sandisk Extreme Pro Mi...
£79.29
