We’re really sorry but we currently have no stock of this product. You can either register below using 'Notify Me' and we will email you when we get more stock, or you can browse alternative items we have available today. Just a small point to note - they might not have the exact features as the product you initially wanted so please be sure to check the details before you buy.
The WSECS1 specially designed to work with the Amazon Echo Show 8. Offering up to 50-degrees of device up-tilt and 28-degrees of down-tilt, this stand is perfect for video calling. Full, 360-degree swivel capability lets you point your Amazon Echo Show 8 in any direction you'd like. Easy-Glide Magnet Technology provides smooth device tilt and swiveling. Durable design and sturdy rubber-ring footing prevent slipping and sliding.
Product Features
Designed for Amazon Echo Show 8
Stable magnetic design prevents unwanted movement and drifting.
Swivels up to 360° for the perfect view wherever you need it.
Durable design and sturdy rubber-ring footing prevents slipping and sliding.
No assembly required. Connect to your Echo Show 8 and it’s ready for use!
Tilt for easy viewing and to eliminate glare.
50° of up tilt and 28° of down tilt for optimal positioning
Product Description | Sanus - stand - for smart display - white | Product Type | Stand - desktop | Adjustments | Tilt, swivel | Recommended Use | Smart display | Colour | White | Designed For | Amazon Echo Show 8 |
General | |
Colour | White |
AV Furniture | |
Type | Stand |
Placing / Mounting | Desktop |
Compatibility Information | |
To help you find items available at this time, we’re only showing items we have in stock to avoid backorders. Pop your email address below and we’ll let you know when this item is back in stock:
