Sanus SimplySafe Fixed Position TV Wall Mount - 22"-50&q...
Sanus SimplySafe Fixed Position TV Wall Mount - 22"-50" TVs
£29.98
Delivery:
Notify me
Key features
  • Easy to install
  • Lateral shift allows TV to slide left and right for perfect TV placement, even with off-center studs
  • Locking system secures your TV to the wall
  • Position your TV as close to the wall as possible
  • Type: Mounting kit
Product codes
The Sanus SimplySafe mount is a low-profile wall mount solution for most 22" - 50" flat-panel TVs up to 80 lbs. Its low-profile design places the TV just 1.1" from the wall, so it hangs like a work of art. Angled slots and an integrated level make leveling and installation quick and easy. A safety latch secures your TV to the wall for added safety.
Product Description Sanus SimplySafe VML41 - mounting kit - for TV
Product Type Mounting kit
Mounting Components Fixed wall mount
Dimensions (WxDxH) 45.09 cm x 7.04 cm x 2.84 cm
Tilt
Adjustments Tilt
Weight 1.77 kg
Recommended Use TV
Recommended Display Size 22"-50"
VESA Mounting Interface 100 x 100 mm, 75 x 75 mm, 200 x 200 mm, 400 x 300 mm, 400 x 100 mm, 400 x 200 mm, 400 x 400 mm, 300 x 200 mm, 300 x 100 mm, 200 x 100 mm, 300 x 300 mm, 100 x 200 mm, 200 x 300 mm, 300 x 400 mm
Max Load Weight 36.29 kg
Colour Black
Manufacturer Warranty 10 years warranty
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
£29.98
Notify me
