Sanus SimplySafe Fixed Position Wall Mount - 47"-80"...
Sanus SimplySafe Fixed Position Wall Mount - 47"-80" TVs
£39.99
Hurry, only 1 left in stock!
Delivery:
Standard: 1-3 working days
Key features
  • Easy to install
  • Hardware included
  • Lateral shift allows TV to slide left and right for perfect TV placement, even with off-center studs
  • Locking system secures your TV to the wall
  • Position your TV as close to the wall as possible
  • Type: Mounting kit
  • Stock Status: In Stock
Product codes
Low-profile fixed wall mount solution for most 47–80" flat-panel TVs. Design places the TV just over 1" from the wall. Angled slots and integrated level make levelling and installation quick and easy. Lateral shift allows TV to slide left and right for perfect TV placement, even with off-center studs. Safety latch secures the TV to the wall for added safety.
For 47-80" Screens
Maximum Supporting Weight 61kg
With Locking Mechanism
Aluminium & Steel Construction
For Internal Use
Close-to-Wall Positioning
Product Description Sanus SimplySafe VLL61-B2 - mounting kit - for TV
Product Type Mounting kit
Mounting Components Fixed wall mount
Recommended Use TV
Recommended Display Size 47"-80"
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
£39.99
