We’re really sorry but we currently have no stock of this product. You can either register below using 'Notify Me' and we will email you when we get more stock, or you can browse alternative items we have available today. Just a small point to note - they might not have the exact features as the product you initially wanted so please be sure to check the details before you buy.
Seamlessly integrate Sonos Beam with your mounted TV with the Soundbar Mount for Beam. The 12" of height adjustment ensures an ideal fit between Beam and the bottom of your mounted TV for a clean, streamlined look, and the intuitive Smart Latch allows for speaker height adjustment with just the lift of a finger - no tools required.
Compatible with Sanus TV mounts and other mount brands, the Soundbar Mount for Beam works with a large range of TV sizes and features broad VESA compatibility. When used with a full-motion TV mount, the soundbar mount allows Beam to move with the TV for an optimal listening experience.
Product Description | Sanus WSSBM1-B2 - mounting kit - for sound bar | Product Type | Mounting kit - under-the-TV | Mounting Components | Shelf bracket, washers, screws, vertical assembly, 2 extension arms | Recommended Use | Sound bar | Material | Metal | Designed For | Sonos Beam |
General | |
Material | Metal |
AV Furniture | |
Type | Mounting kit |
Placing / Mounting | Under-the-TV |
Compatibility Information | |
To help you find items available at this time, we’re only showing items we have in stock to avoid backorders. Pop your email address below and we’ll let you know when this item is back in stock:
