We’re really sorry but we currently have no stock of this product. You can either register below using 'Notify Me' and we will email you when we get more stock, or you can browse alternative items we have available today. Just a small point to note - they might not have the exact features as the product you initially wanted so please be sure to check the details before you buy.
The SANUS VuePoint F215c is a versatile full-motion wall mount solution for most 32" - 47" flat-panel TVs up to 60 lbs. Its full range of movement allows smooth extend, tilt, swivel and roll motions up to 15.4" from the wall without the use of tools. The F215c tilts ±15º with the touch of a finger, making it easy to reduce glare. In-arm cable management channel conceals cables the length of the mount for a seamless appearance.
Product Description | Sanus VuePoint - mounting kit - for flat panel | Product Type | Mounting kit | Mounting Components | Full motion wall mount | Tilt | 30° | Pan | 90° | Recommended Use | Flat panel | Recommended Display Size | 32"-47" | VESA Mounting Interface | Up to 400 x 400 mm | Max Load Weight | 27 kg |
AV Furniture | |
Cable Management | Integrated cable management |
Tilt | 30° |
Pan | 90° |
The following resources are available for the Sanus VuePoint Full-Motion Mount - 32"-47" TVs
To help you find items available at this time, we’re only showing items we have in stock to avoid backorders. Pop your email address below and we’ll let you know when this item is back in stock:
