Sanus VuePoint Full-Motion Mount - 47"-70" TVs
£79.99
Delivery:
Notify me
Key features
  • Conceal unsightly cables
  • Easily adjust your TV without tools
  • Easy to install
  • Enjoy a great picture no matter where you watch
  • Leveling adjustments allow TV to be perfectly positioned after hanging
  • Post-installation micro adjustments make for effortless projector registration
  • Type: Mounting kit
Product codes
Documents
The Sanus VuePoint F180c is a versatile full-motion wall mount solution for most 47" - 70" flat-panel TVs. Its full range of movement allows smooth extend, tilt, swivel and roll motions up to 15" from the wall without the use of tools. The F180c tilts +11º/-12º with the touch of a finger, making it easy to reduce glare. Cable management tie clips conceal and organize cables the length of the mount for a seamless appearance. Lateral shift ensure perfect TV placement, even with off-center wall studs.
Product Description Sanus VuePoint - mounting kit - for flat panel
Product Type Mounting kit
Mounting Components Full motion wall mount
Tilt 23°
Pan 120°
Recommended Use Flat panel
Recommended Display Size 47"-70"
VESA Mounting Interface Up to 600 x 400 mm
Max Load Weight 45 kg
Resources
The following resources are available for the Sanus VuePoint Full-Motion Mount - 47"-70" TVs
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
£79.99
Notify me
