We’re really sorry but we currently have no stock of this product. You can either register below using 'Notify Me' and we will email you when we get more stock, or you can browse alternative items we have available today. Just a small point to note - they might not have the exact features as the product you initially wanted so please be sure to check the details before you buy.
The Sanus VuePoint F32b is an unparalleled wall mount solution for most 32"-47" flat-panel TVs up to 80 lbs. Its low-profile design sits just 0.9" from the wall for a flush appearance that makes it great for ultra-thin TVs. Its lateral shift feature allows the brackets to move left and right on the wall plate for perfect TV placement, even with off-center wall studs. A latching mechanism holds TV securely on the wall.
Product Description | Sanus VuePoint F32b - mounting kit - Low Profile Mount - for TV | Product Type | Mounting kit (Low Profile Mount) - wall-mountable | Mounting Components | Wall mount | Dimensions (WxDxH) | 39.37 cm x 2.29 cm x 43.03 cm | Recommended Use | TV | Recommended Display Size | 32"-47" | VESA Mounting Interface | 100 x 100 mm, 75 x 75 mm, 200 x 200 mm, 400 x 300 mm, 400 x 200 mm, 400 x 400 mm, 200 x 100 mm | Max Load Weight | 36.36 kg | Manufacturer Warranty | 5-year warranty |
General | |
Width | 39.37 cm |
Depth | 2.29 cm |
Height | 43.03 cm |
AV Furniture | |
Type | Mounting kit |
Design | Low Profile Mount |
Placing / Mounting | Wall-mountable |
Features | Lateral shift |
Manufacturer Warranty | |
Service & Support | Limited warranty - 5 years |
To help you find items available at this time, we’re only showing items we have in stock to avoid backorders. Pop your email address below and we’ll let you know when this item is back in stock:
