We’re really sorry but we currently have no stock of this product. You can either register below using 'Notify Me' and we will email you when we get more stock, or you can browse alternative items we have available today. Just a small point to note - they might not have the exact features as the product you initially wanted so please be sure to check the details before you buy.
The Sanus VuePoint F55c is a superior wall mount solution for most 47" - 80" flat-panel TVs up to 130 lbs. Its ultra low-profile design sits just 1" from the wall to maximize the sleek, thin look of the TV. Brackets easily shift left and right on the wall plate to allow perfect TV placement, even with off-center wall studs. A quick latching mechanism holds the TV securely on the wall for added safety. The F55b is pre-assembled and is easily installed in minutes. Solid construction is strong and durable.
Product Description | Sanus VuePoint F55c mounting kit - for flat panel - black | Product Type | Mounting kit | Mounting Components | Wall mount | Dimensions (WxDxH) | 69.34 cm x 2.54 cm x 48.51 cm | Recommended Use | Flat panel | Recommended Display Size | 47"-80" | VESA Mounting Interface | From 75 x 75 mm, up to 675 x 405 mm | Max Load Weight | 59 kg | Colour | Black | Manufacturer Warranty | 5-year warranty |
General | |
Width | 69.34 cm |
Depth | 2.54 cm |
Height | 48.51 cm |
Colour | Black |
AV Furniture | |
Manufacturer Warranty | |
Service & Support | Limited warranty - 5 years |
The following resources are available for the Sanus VuePoint Low-Profile Wall Mount - 47"-80" TVs
