We’re really sorry but we currently have no stock of this product. You can either register below using 'Notify Me' and we will email you when we get more stock, or you can browse alternative items we have available today. Just a small point to note - they might not have the exact features as the product you initially wanted so please be sure to check the details before you buy.
Sanus VuePoint FPA400 is a single-column AV component system that mounts directly under wall-mounted TVs for a sleek, streamlined look. Its center column features an integrated channel for easy power cable and signal wire routing. Thick tempered-glass shelf support up to 15 lbs and can be vertically adjusted to accommodate any AV component arrangement. Combine more than one FPA400 for a multiple shelving unit.
Product Description | Sanus VuePoint FPA400 - mounting component | Product Type | Mounting component | Mounting Components | Shelf | Recommended Use | AV System | Colour | Black |
General | |
Colour | Black |
AV Furniture | |
The following resources are available for the Sanus VuePoint Single Accessory Shelf TV Wall Bracket
To help you find items available at this time, we’re only showing items we have in stock to avoid backorders. Pop your email address below and we’ll let you know when this item is back in stock:
