Sanus VuePoint Tilting Wall Mount - 47"-80" TVs
£44.98
Delivery:
Notify me
Key features
  • Locking system secures your TV to the wall
  • Post-installation micro adjustments make for effortless projector registration
  • Tilt your TV for perfect viewing from the couch or floor
  • Type: Mounting kit
Product codes
Documents
The SANUS VuePoint F58c is an unparalleled wall mount solution for most 47" - 80" flat panel TVs up to 130 lbs. This mount features an exclusive tilting technology for effortless adjustment of viewing angles, helping to reduce glare with up to 15º of tilt without the use of tools. Its low-profile design places the TV just 2" from the wall for a clean, flush appearance. Laterally adjustable TV brackets allow the mount to shift left and right on the wall plate for perfect placement, even with off-center wall studs. A quick latching mechanism holds the TV securely on the wall, and solid construction provides strength and durability.
Product Description Sanus VuePoint - mounting kit - for flat panel
Product Type Mounting kit
Mounting Components Tilt wall mount
Tilt 15°
Recommended Use Flat panel
Recommended Display Size 47"-80"
VESA Mounting Interface Up to 800 x 600 mm
Max Load Weight 59 kg
Resources
The following resources are available for the Sanus VuePoint Tilting Wall Mount - 47"-80" TVs
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
£44.98
Notify me
