We’re really sorry but we currently have no stock of this product. You can either register below using 'Notify Me' and we will email you when we get more stock, or you can browse alternative items we have available today. Just a small point to note - they might not have the exact features as the product you initially wanted so please be sure to check the details before you buy.
The VuePoint FPA405 soundbar mount attaches directly to wall mounts and positions the soundbar below mounted TVs. It supports up to 15 lbs, and is easy to assemble.
Product Description | Sanus VuePoint - mounting kit - for sound bar | Product Type | Mounting kit - wall-mountable | Mounting Components | 2 mounting brackets | Recommended Use | Sound bar | Max Load Weight | 6.8 kg |
AV Furniture | |
Type | Mounting kit |
Placing / Mounting | Wall-mountable |
The following resources are available for the Sanus VuePoint Universal Soundbar Mount
To help you find items available at this time, we’re only showing items we have in stock to avoid backorders. Pop your email address below and we’ll let you know when this item is back in stock:
