Sapphire Technology ATI Radeon 6850 HD 775MHz 2GB PCI-Express...
Sapphire Technology ATI Radeon 6850 HD 775MHz 2GB PCI-Express HDMI
Key features
  • Microsoft DirectX 11 support
  • ATI Eyefinity technology
  • AMD HD3D technology
  • AMD Advanced Parallel Processing technology
  • Third generation TeraScale engine
  • Advanced 256-bit GDDR5 memory interface
  • On chip HDCP support
  • ATI CrossFireX multi-GPU support for highly scalable performance
  • Enhanced Unified Video Decoder (UVD)
  • Dynamic power management with ATI PowerPlay technology
  • Dolby TrueHD and DTS HD Master Audio support
  • Enhanced Internet browser applications
Product codes
The Sapphire HD 6800 series features the second generation of graphics technology from AMD designed to support all the features of Microsoft DirectX 11 and DirectCompute 11. The new GPU's are built in AMD's 40nm process to deliver high performance with low power consumption. Advanced hardware features include an enhanced Tesselation unit, dedicated HDR Texture compression, multi-threaded communication with system CPU cores, embedded support for many of the DirectCompute 11 instructions, 3D stereoscopic support and HDMI 1.4a.
  • Dual-Link DVI
  • HDMI 1.4a
  • DisplayPort
  • Single-Link DVI-D
  • DisplayPort 1.2
  • Advanced GDDR5 Memory Technolog
  • AMD Eyefinity
  • 40nm Process Technology
  • PCI-Express 2.0
  • AMD HD3D Technology
  • OpenGL 4.1
  • Shader Model 5.0
  • AMD Catalyst Control Center
  • Dolby TrueHD and DTSHD Master Audio Support
  • AMD PowerPla
  • Display Flexibility
  • TriXX Utility
  • Enhanced Unified Video Decoder 3 (UVD 3)
  • Enhanced Internet Browser Applications
  • Microsoft Office 2010
  • Windows 7 support
  • AMD App Acceleration
  • 2 Years Manufacturers Warranty
Spec
  • Output: 1 x Dual-Link DVI, 1 x HDMI 1.4a, 1 x DisplayPort, 1 x Single-Link DVI-D, DisplayPort 1.2
  • GPU: 775 MHz Core Clock, 40 nm Chip, 960 x Stream Processors
  • Memory: 2048 MB Size, 256 -bit GDDR5, 4000 MHz Effective
  • Software: Driver CD, Sapphire TriXX Utility
  • Accessory: CrossFire Bridge Interconnect Cable, DVI to VGA Adapter, 6 PIN to 4 PIN Power Cable
  • Warranty: 2 Years Manufacturers Warranty
Product Description Sapphire RADEON HD 6850 - graphics card - Radeon HD 6850 - 2 GB
Device Type Graphics card
Bus Type PCI Express 2.0 x16
Graphics Engine AMD Radeon HD 6850
Memory 2 GB GDDR5
Core Clock 775 MHz
Stream Processors 960
Effective Memory Clock 4 GHz
Memory Interface 256-bit
Max Resolution 2560 x 1600
Max Resolution Details DVI: 2560 x 1600 / DisplayPort: 2560 x 1600 / HDMI: 1920 x 1080 / VGA: 2048 x 1536
Interfaces DVI-I (dual link) , HDMI , DisplayPort , DVI-D (Single-Link) , VGA - with adapter
API Supported DirectX 11, OpenGL 4.1
Package Type Lite retail
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
Sapphire Technology AT...
