We’re really sorry but we currently have no stock of this product. You can either register below using 'Notify Me' and we will email you when we get more stock, or you can browse alternative items we have available today. Just a small point to note - they might not have the exact features as the product you initially wanted so please be sure to check the details before you buy.
Featuring enhanced scissor-switch keys and an extended keyboard layout, the Satechi Aluminum Wired Keyboard is a perfect solution for your Mac setup. Designed for Mac devices, the keyboard includes intuitive MacOS function hot keys for convenience at your fingertips. Highly responsive scissor-switch keys capture every keypress, ideal for everyday data entry or advanced accounting projects. Available in elegant color options to create the ideal keyboard for your modern desk space.
Product Description | Satechi Aluminum Wired Keyboard - keyboard - UK - silver | Device Type | Keyboard | Interface | USB | Connectivity Technology | Wired | Localization and Layout | UK | Hot Keys Function | Application switching, search, mute, brightness, play/pause, previous track, next track, Mission Control, volume -, volume +, Fn key lock, eject | Numeric Keypad | Yes | Colour | Silver | Dimensions (WxDxH) | 43.2 cm x 11.9 cm x 1.02 cm | Weight | 476 g | Manufacturer Warranty | 1-year warranty | Designed For | Apple iMac; iMac Pro (Late 2017); Mac mini (Late 2018); Mac Pro (Late 2013, Late 2019); MacBook (Early 2015, Early 2016, Mid 2017); MacBook Air (Early 2020, Late 2018, Mid 2019); MacBook Pro |
General | |
Interface | USB |
Input Device | |
Keyboard Technology | Scissors |
Features | Numeric keypad |
Width | 43.2 cm |
Depth | 11.9 cm |
Height | 1.02 cm |
Weight | 476 g |
Miscellaneous | |
Colour | Silver |
Cable Length | 1.4 m |
Software & System Requirements | |
OS Required | Apple MacOS X 10.4 or later |
Manufacturer Warranty | |
Service & Support | Limited warranty - 1 year |
Compatibility Information | |
Designed For | Apple iMac , Apple iMac Pro (Late 2017) , Apple Mac mini (Late 2018) , Apple Mac Pro (Late 2013, Late 2019) , Apple MacBook (Early 2015, Early 2016, Mid 2017) , Apple MacBook Air (Early 2020, Late 2018, Mid 2019) , Apple MacBook Pro |
To help you find items available at this time, we’re only showing items we have in stock to avoid backorders. Pop your email address below and we’ll let you know when this item is back in stock:
