We’re really sorry but we currently have no stock of this product. You can either register below using 'Notify Me' and we will email you when we get more stock, or you can browse alternative items we have available today. Just a small point to note - they might not have the exact features as the product you initially wanted so please be sure to check the details before you buy.
Complete your modern desk space - while working remotely or from home - with the Satechi Slim X3 Bluetooth Backlit Keyboard. Designed for Mac devices, the X3 Keyboard features an extended layout with numeric keypad, multi-device Bluetooth, and shortcut keys optimized for Apple devices - all with an ultra-slim, modern design. Equipped with adjustable backlit keys and a rechargeable USB-C port, the keyboard allows you to work with ease wherever or whenever your creativity takes you.
Details
Designed for Apple users in mind
Extended layout with numeric keypad
Connects up to four Bluetooth devices
Illuminated keys & rechargeable battery
Product Description | Satechi Slim X3 - keyboard - QWERTY - UK | Device Type | Keyboard | Backlit | Yes | Interface | Bluetooth 3.0, USB-C | Connectivity Technology | Wireless, wired | Localization and Layout | QWERTY UK | Hot Keys Function | Application switching, search, mute, brightness, play/pause, previous track, next track, backlight control, volume -, volume +, Fn key lock, Bluetooth, eject | Numeric Keypad | Yes | Dimensions (WxDxH) | 42.3 cm x 11.4 cm x 1.02 cm | Weight | 440 g | Manufacturer Warranty | 1-year warranty |
General | |
Backlit | Yes |
Input Device | |
Type | Wireless |
Detachable Cable | Yes |
Features | Numeric keypad |
Width | 42.3 cm |
Depth | 11.4 cm |
Height | 1.02 cm |
Weight | 440 g |
Miscellaneous | |
Included Accessories | USB-C charging cable |
Software & System Requirements | |
OS Required | Apple MacOS, Apple iOS |
Battery | |
Type | Rechargeable |
Manufacturer Warranty | |
Service & Support | Limited warranty - 1 year |
To help you find items available at this time, we’re only showing items we have in stock to avoid backorders. Pop your email address below and we’ll let you know when this item is back in stock:
