Seagate 10TB BarraCuda Pro 3.5" 256MB 7200RPM SATA 6Gb/s...
Seagate 10TB BarraCuda Pro 3.5" 256MB 7200RPM SATA 6Gb/s HDD
£344.37
34 in stock
Delivery:
Standard: 1-3 working days
Key features
  • Large onboard cache is designed to quickly access frequently-used applications and files
  • BarraCuda Pro draws a mere 6.8 W, making it one of the lowest-power 3.5-inch drives on the market
  • Store data faster with SATA 6 Gb/s interface that optimizes burst performance
  • Up to 220 MB/s maximum sustained transfer rate
Product codes
Lightning-fast performance and titanic storage up to 10TB give your desktop or creative professional system the edge you need to be your very best.
Seagate Barracuda Pro ST10000DM0004 - hard drive - 10 TB - SATA 6Gb/s
Hard drive - internal
10 TB
3.5"
SATA 6Gb/s
Data Transfer Rate
600 MBps
Buffer Size
256 MB
Spindle Speed
7200 rpm
Native Command Queuing (NCQ), Halogen Free, PowerChoice, Hot-Plug Support, advanced format 512e, S.M.A.R.T.
101.85 mm x 146.99 mm x 26.11 mm
650 g
5 years warranty
Customer reviews
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
Seagate 10TB BarraCuda...
£344.37
