Seagate 12TB IronWolf 3.5" SATA 6GB/s 7200RPM Hard Drive
£389.98
Select:
  • 12TB
More than 50 in stock
Delivery:
Standard: 1-3 working days
Key features
  • Optimized for NAS with AgileArray which is built for dual-plane balancing and RAID optimization in multi-bay environments with the most advanced power management possible
  • High performance means no lag times or downtime for users during high traffic time for the NAS
  • Scalable solution for any NAS use-case scenario
  • Get ahead with more cache. IronWolf provides high-cache options allowing your NAS to serve data faster
  • Do more with multi-user technology
  • Multiple users can confidently upload and download data to the NAS server, knowing it can handle the workload, whether you're a creative professional or small business
  • Designed for always on, always accessible 24/7 performance
  • Access your data on your NAS any time, remotely or on site
  • Form Factor: 3.5"
  • Type: Hard drive
  • Capacity: 12TB
  • Spin Speed (rpm): 7200rpm
  • Stock Status: In Stock
Product codes
The Power of Agility for home, SOHO and SMB NAS enclosures. IronWolf is designed for everything NAS. Get used to tough, ready and scalable 24/7 performance that can handle multi-drive environments with a wide range of capacities.
Product Description Seagate IronWolf ST12000VN0007 - hard drive - 12 TB - SATA 6Gb/s
Type Hard drive - internal - Native Command Queuing (NCQ), PowerChoice, advanced format 512e
Capacity 12 TB
Form Factor 3.5"
Interface SATA 6Gb/s
Data Transfer Rate 600 MBps
Buffer Size 256 MB
Spindle Speed 7200 rpm
Features Native Command Queuing (NCQ), PowerChoice, advanced format 512e
Dimensions (WxDxH) 101.85 mm x 146.99 mm x 26.11 mm
Weight 705 g
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
Seagate 12TB IronWolf...
£389.98
