Seagate 12TB IronWolf 3.5" SATA 6GB/s 7200RPM Hard Drive
Select:
  • 12TB
Key features
  • Optimized for NAS with AgileArray which is built for dual-plane balancing and RAID optimization in multi-bay environments with the most advanced power management possible
  • High performance means no lag times or downtime for users during high traffic time for the NAS
  • Scalable solution for any NAS use-case scenario
  • Get ahead with more cache. IronWolf provides high-cache options allowing your NAS to serve data faster
  • Do more with multi-user technology
  • Multiple users can confidently upload and download data to the NAS server, knowing it can handle the workload, whether you're a creative professional or small business
  • Designed for always on, always accessible 24/7 performance
  • Access your data on your NAS any time, remotely or on site
Product codes
The Power of Agility for home, SOHO and SMB NAS enclosures. IronWolf is designed for everything NAS. Get used to tough, ready and scalable 24/7 performance that can handle multi-drive environments with a wide range of capacities.
Product Description Seagate IronWolf ST12000VN0007 - hard drive - 12 TB - SATA 6Gb/s
Type Hard drive - internal - Native Command Queuing (NCQ), PowerChoice, advanced format 512e
Capacity 12 TB
Form Factor 3.5"
Interface SATA 6Gb/s
Data Transfer Rate 600 MBps
Buffer Size 256 MB
Spindle Speed 7200 rpm
Features Native Command Queuing (NCQ), PowerChoice, advanced format 512e
Dimensions (WxDxH) 101.85 mm x 146.99 mm x 26.11 mm
Weight 705 g
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
Seagate 12TB IronWolf...
